Will-C
- Joined
- Aug 21, 2007
- Messages
- 2,476
- Reaction score
- 2
- C Dory Year
- 2008
- C Dory Model
- 23 Venture
- Hull Identification Number
- CD023007A808
- Vessel Name
- Will-C
It almost seems the 4800 pounds would maybe be the bare hull. No motor and no water gas batteries etc.
I pulled an 08 23' C-Dory Venture (5500 pounds on a trailer_ it was loaded moderately with a Chevy 1500 with 4 wheel drive for about 5000 miles. The motor was ok but I don't think the transmission much cared for the weight. Even on slight hills the downshifts were not pretty. Our 5.3 V8 had to be spooled up (higher RPM's) to make power. It was a 2001 with only a four speed automatic. We bit the bullet and bought a new 3/4 ton 4x4 diesel in 2009. That has proved to be a good decision as we now have a larger boat that on a trailer is about 10 to11 thousand pounds. Our truck has no problem pulling it. Pulling close to 10k is time to consider at least consider a diesel 3/4 ton. There are minimalists who have done it with lighter trucks and with 2 wheel drive but I believe they later saw the light and moved up to 3/4 ton. If you are not towing a lot the gas engine will be ok but a lot more thirsty that a diesel that is equipped with a transmission made for towing. Over 40 thousand miles the difference in 4 or 5 miles to the gallon can add up to more than you would think. The diesel purchased new or used with 4 wheel drive will hold their value pretty well. Longer wheel based trucks ride nicer and track straighter. Harder to park not good for a daily driver.
D.D.
D.D.
