Well-known member
- Joined
- Nov 2, 2003
- Messages
- 21,808
- Reaction score
- 152
- C Dory Year
- 2007
- C Dory Model
- 25 Cruiser
- Hull Identification Number
- DOR25652A707
- Vessel Name
- thataway
I agree with the comment that you haven't been boating a lot (all relative) if you haven't hit something--especially in the PNW. In over 230,000 miles of boating, I have hit a lot of things, with a lot of different props. This includes a whale shark, a large sea turtle, logs, cables, nets, tarps, tree limbs, some rocks and outcroppings, etc. One boat I was sailing on hit a shipping container, and impacted the hull. Most boats would have been holed and sunk--but this boat had a 3" thick balsa core, which impacted and the inner layer of glass was not breeched. One might say, how would you not see a shipping container, log etc--these types of things happen at 0 dark 30, often in winds over 50 knots and seas which are much higher than one wants to be in.....but bad things can happen.
I have changed both outboard, and inboard props when in the water--not fun, but at time necessary. I used to change a folding prop which I had on a sailboat for racing, to a solid cruising prop for powering, at least once a week, in three free dives--this did involve a net bag to hold parts etc.
The easiest way to change a C Dory outboard prop on the water is from a dinghy. One of the reasons to carry a dinghy, even if you never need it to get to shore. Changing an outboard prop in shallow water at Powell is like changing it on the trailer.
RobLL, there are some very basic mechanical things you need to be able to do on a boat like the C Dory--changing a prop is one of those. Also changing the lower unit oil is in the category. Also I consider knowing some basics of 12 volt electrical systems is also essential.
I agree with those who say that having a kicker of some type is also essential. Some will argue that some towing policy is enough. Many places the tow boat cannot not get to you in a timely fashion, and you may save your boat and self by having an engine to keep way on. One might argue throw out an anchor--but many places the water is too deep, too close to the shore, to get an anchor to hold in time...
