Pacificcoast101
We had just throttled up outside the marina when the starboard motor revved up and the overheating light and alarm sounded. I shut the motor down immediately and checked for kelp or plastic blocking the intake. Everything was clear. After a few minutes, I started the motor but despite the throttle shifting into gear, the propeller wouldn't spin.
We came back in under the power of the other motor. Back in the slip, I found that the propeller will lock while in forward and reverse gears and spin while in neutral, but will not turn with the motor on. There is also no pee stream. I'm going to haul the boat out and replace the impeller but was wondering if the prop not turning is a safety feature in the motor or do I have bigger problems to deal with?
