kennharriet
- Joined
- Jan 22, 2009
- Messages
- 576
- Reaction score
- 16
- C Dory Year
- 1999
- C Dory Model
- 22 Cruiser
- Vessel Name
- Lochsa
I recently added two AGM house batteries in addition to the start battery. The way I read the ABYC standards there should be a circuit breaker between the house batteries and the distribution system to protect that length of wire between the batteries and distribution system behind the helm. That is not the case from the factory. It says the capacity of the breaker should not exceed 150% of the maximum potential downstream load. Both the house and start batteries are connected with a Yardina combiner. My house distribution system is the factory fuse system behind the helm.
What type and size of circuit breaker should I use if one is required? It makes sense to me to use a switched breaker for quick disconnect in an emergency with manual reset.
I have the windless on the start battery on it’s on circuit breaker. Otherwise I have the typical house load of led lights, nav lights, anchor light, cell and iPad charging, vhf, chart plotter and the Wallas 1300 heater.
Thanks in advance. I admire all the experienced wisdom in the group.
