Well-known member
- Joined
- Nov 2, 2003
- Messages
- 21,793
- Reaction score
- 140
- C Dory Year
- 2007
- C Dory Model
- 25 Cruiser
- Hull Identification Number
- DOR25652A707
- Vessel Name
- thataway
John,
My Tom Cat 255 also came with an unusual battery configuration. I changed the wiring to some extent. You want to be able to use switches or relays to isolate the house batteries and starting battery. You are correct that one engine start is plenty to start the two engines which you own. But there is a risk that the house/engine start could run down, and the other start fail (very slight)--but I do like to isolate two starting batteries, and then have a separate house bank. You may have noted that I carried a U1 battery (Garden tractor) extra battery fully charged. One of these has plenty of power to start an outboard--probably would start two. It is better than one of the "jump start" kits, and cheaper.
Good luck with your decision--no matter what, you will do well.
