Kushtaka
- Joined
- Dec 17, 2013
- Messages
- 648
- Reaction score
- 0
- C Dory Year
- 1993
- C Dory Model
- 22 Cruiser
I have a mini ACR, and have discovered a very new anxiety!! My start battery is charging and isolating just fine, but my house battery is not charging at all. I've verified this with meters to each battery while charging via alternator, and with the motor off.
This is new! Just happened yesterday. I was out fishing, watching sonar, listening to the radio, and then went to haul my anchor, and things started shutting off, and the windlass labored.
I had to connect both batteries with the emergency switch to get the anchor up. I had just set a longline as well, and today I had to go out to haul the longline and do the same. I kept both batteries connected the trip out to get the house battery charged as well.
The new anxiety I'm having is the fact that my fuel line passes right in front of my charging relay. I'll figure out how to re-route the fuel later, but I really want to not worry about this issue.
I have yet to get into it. My plan is to work through the wiring diagram from the house battery backwards, and find something loose, tightening everything as I go.
Is anyone familiar enough with these systems to tell me precisely where to look? My setup is a little tough to access, and if there were a part I could avoid taking apart I'd be happy.
