Active member
- Joined
- Mar 1, 2005
- Messages
- 7,510
- Reaction score
- 18
- C Dory Year
- 2007
- C Dory Model
- 25 Cruiser
- Hull Identification Number
- TBA
- Vessel Name
- "Wild Blue" (sold 9/14)
With discussions of ethanol, rising fuel prices, altering travel plans, and what our boats really get for mileage, this thread is for tips on what you do to get the most out of each gallon of gas.
Of course, slowing down makes a BIG difference with our boat. We can get better than 5 mpg if we run at displacement speed, dropping to less than 2.5 miles per gallon if we choose to run faster. I consider that a trade off: if you're willing to pay twice as much for fuel use, you get where you're going in less than half the time. If it's the destination and not the journey... whether you're on a schedule or not... and, budget constraints. Choices.
Keep the boat light. Easy to do when we're in our home waters; not so easy when we're cruising and have to deal with the uncertainties of resupplying along the way.
Which leads me to fuel. At over 6 pounds per gallon, a full fuel tank on our 25 weighs over 600 pounds. It squats the aft end of the boat and we have to use more throttle and trim tabs to get on plane. If we are day-tripping locally, we keep the tank less than half full - no point in carrying all that fuel around when fuel is easily available. Unless, like currently, fuel is going up faster than they can change the signs at the gas stations. So, you have to "play the futures" somewhat. A balancing act.
And if you don't top off your tank all the time, your fuel use is a guesstimate at best. Another reason I like having a fuel flow meter. Use of it over the years has shown that it is pretty darn accurate. And we also use that fuel flow meter to trim the boat for best fuel burn at any particular speed or rpm.
And speaking of RPM, a couple hundred can make a big difference, especially if you are OK with traveling slow. On our boat, the difference between 1800 rpm and 2100 rpm is a 30% increase in fuel burn (1 gallon per hour vs 1.3 gallons per hour). 3/10 of a gallon per hour doesn't seem like much until you figure the percentages. Same thing applies when we are running at a higher speed - a couple miles per hour may vary the fuel burn by a couple tenths.
We try to avoid ethanol. Not easy to do anymore when the nearest station reporting that they sell "non-ethanol" gas is over 80 miles away... on land. Ethanol, besides all the nasty stuff we've discussed in other threads, is less efficient as a fuel than pure gasoline - add it to your fuel and you will get lower mpg. Swell.
So, what else is everyone doing? (NOT using the boat is not a valid consideration for some of us.)
