I didn't really make my point well. The benefit of this type of course (because it teaches the student to breakdown various aspects of a boat's control inputs individually) is ideally suited to help you overcome starting with a larger boat than you might otherwise think prudent. The 25 isn't that big, and you will have a learning curve regardless. The suggestion of this particular course was because it would help you deal with this concern directly.
That said:
I stand by this course. NSBC has been doing this since 1958. I just completed a training with Alaska State Parks, USDA, Alaska Dept. of Environmental Conservation, all of whom not only had operators certified, but had instructors certified in order to be able to use and credential their operators in this curriculum.
It is a serious course that is used by professionals, and one of the very few on-water courses delivered with a consistent curriculum across the country.
Also, when I give the course, I do not take any money, I only cover costs. If you use your own boat (and the OP should) the course should cost less, and you get the benefit of having your boat inspected and gone through by a pro (as part of the course, boat systems inspections and pre-departure checklists are conducted and taught).
It's not a sales pitch. I participate in this program because I respond to search and rescue calls, and this is much easier. It saves lives.
For some info:
http://www.safeboatingcouncil.org/training
For some info:
