Active member
- Joined
- Nov 21, 2004
- Messages
- 5,934
- Reaction score
- 4
- C Dory Year
- 2008
- C Dory Model
- 255 Tomcat
- Vessel Name
- Meant to be
Does anyone have (an) image(s) (from a service manual perhaps) that they can post that will show me how the lower unit on a Honda BF 40 is coupled to the upper unit? My question stems from the problem I experienced on my boat over the weekend after work had been done on it at a local dealer. In brief, the work that was done was 100 hr service plus a change of the impeller. The engine ran fine for 2-3 hours and then wouldn't shift into gear. Fortunately, I have twins so I could make it back to port without a tow.
I took the boat back to the repair shop and they have fixed it. They indicated that there is a shaft the runs from the upper unit to the lower unit and that some bolts that hold it in place came loose. Without a diagram to know what is reallly inside, I assume the shaft runs through some retainer with a bearing in it that is bolted in place. Anyway, they indicated that they added locktite to the fasteners and re-tightened them and also disassemble the 2nd engine to do the same so that the problem wouldn't re-occurr.
What concerns me is the potential for additional damage being caused whenever this came loose so I'd like to understand in more detail how the damn thing works. I never heard any bad noises, the thing just quit shifting into gear so I hope there was no damage. However, I'm thinking I may still drain the oil on the lower unit and run it through a coffee filter to look for metal pieces.
Any comments/thoughts from the marine mechanics in the crowd?
