jkidd
Active member
I'm raising my main motor up one hole. I knew when I took the motor off that the holes might or might not be done right they were not. Before I took the motor I put a torque wrench on just to see how tight the bolts were. They were sitting at about 20 ft. lbs. So my question would be how tight do you think these bolts should be? Do you think 20 ft. lbs. is enough or should it be more?
