sketchrbob
For those of you who have a compass mounted toward the center of your boat, it may be a little difficult to read the lubber line. An easy solution is to paint a 45° lubber line -- often a standard feature on such compasses as the Ritchie Helmsman --but not included on smaller compasses.
You can paint it on one or both sides if the co-pilot wants to see it. To do this, make a mark 45° from the center lubber line -- if your compass is of the Direct Read variety this would be at 315° with the lubber line reading 0°.
Take two strips of masking tape and tape them to the dome about 1/16" apart either side of your mark. You might want to use a bright yellow enamel for paint. After the paint sets, remove the masking tape and you have your 45° line.
To steer using this, simply set your course by the center lubber line, observe what the yellow 45° line shows and steer by that. Bob W
