...but if it had been a rat it had long ago departed this cruel world. Maybe 50 million years ago. And then compressed by the weight of time, gravity and rock until his corporal being became gloppy gooey stuff contently aging into diamonds. Until some demonic company pierced its security blanket and brought it back to the sunshine where it was subjected to all sorts of modern indignities before I finally took it to sea again.
That's right, I smelled gas.
I have become used to smelling a bit of gas every time I remove the boat cover from my CD 16 but today I knew something was amiss when I smelled it before I even got out of the truck. Yet another government certified safe plastic 6 gallon gas tank had failed That makes two out of three.
This time, at the suggestion of approximately 50.003% of trusted boaters responding to a previous post, I had closed the tank vent. Apparently the tank flexed a bit beyond spex and bingo! gas in the boat
Previously, I had left the vent open to test the theory of 49.007% of boating respondents. Every time I took the cover off the boat I was nearly overwhelmed with fumes.
I don't think the problem lies with the vent open/closed issue
I am thinking about having a couple of metal or fiberglass tanks permanently installed with honest to god fill pipes and vents. It would be so nice to simply pull up to a gas pump and fill the tank.
However, I am open to all suggestions. What say you?
On a separate issue ... I had the dealer install a Garmin gps chartplotter on the C Dory with a transom mount sounder transducer. Figured it would keep me out of the shallows (boat draws 6 inches
) and find all those fish for me.
I have noticed that the transducer does not work properly when I am going any faster than about 3/4 hull speed. At full speed, the transducer throws an impressive rooster tail all its own.
Should I expect this with a transom mount? Should it sit deeper in the water? Would I have the same issue with a through hull transducer?
