Well-known member
- Joined
- Nov 2, 2003
- Messages
- 21,897
- Reaction score
- 239
- C Dory Year
- 2007
- C Dory Model
- 25 Cruiser
- Hull Identification Number
- DOR25652A707
- Vessel Name
- thataway
The CD 25 has a set of Instatrim tabs. There is no motor run or selenoid activation.
I am not sure if a factory or after market installation. The power to the plug on the plastic unit which houses the pump, selenoids and the resivoir is correct (ground is continuity to battery, up and down power, as well as selenoid power P & S show 12 volts.) No obvious corrosion.
The unit with the pump etc is back under the deck, so it is not accessable, and looks like it was installed before the deck was put in place.
I suspect I have to pry off the hyraulic hoses, to get the unit out in the open, and inspect further connections and see if the motor is OK.
Any thoughts about getting these hyraulic hoses off easily? I took the hose clamps off, and no budge. The brass connectors to the manufold do not easily unscrew. (the manual says these are hose barbed connections).
The manual also relates a black ground wire to the motor--not sure if this is the wire in the bundle from the switch (which is fine) or another separate wire. I don't see any separate ground wires to the unit--anyone know if there is a separate ground wire?
If worse comes to worse, I can cut the hoses, put in a connector, and cut the hose off the barbs to the unit--putting in a short lenth of hyraulic hose on each side. Any other suggestions? Anyone else have the Instratrim tabs?
Thanks in advance!
Thanks in advance!
