Interior Paint
Capn Jack
Oct 1, 2007
527
1988
DOR15108E888
Pocket Yacht
I want to paint the inside of my "Angler" and I'm looking for suggestions...
What kind of paint has been found that will stick to the fibreglass and has some kind of mold inhibiters in it? I have just spent over 2 hours (in the fetal position) :crook scrubbing mold off of the interior and I don't want to do it again. :smilep
Can't help much with paint that has mold inhibiters, but when I painted over the Mascoat Insulating paint that is sprayed on last spring, Mascoat recommended a good quality latex acrylic paint. I just purchased the top brand that my local big box had and it worked very well so far. When on easily and seems pretty durable in the six or so months its been in use.
Ron
Happy Thanksgiving Captain Jack,
If your boat has the factory spattered-epoxy paint finish on the interior I'd think a bit before I'd cover it with new paint. That stuff is pretty bulletproof and lasts a good long time. My Classic is 23 years old and the epoxy paint still cleans up just fine. Are you sure you don't have a ventilation problem instead of a paint problem? Mold usually suggests poor ventilation. Of course if your heart is set on new paint, have at it!
Mike
Thanks Mike,
The reason I wanted to paint it is, the boat was pretty moldy when I got it and the "Spatter epoxy" color will make it hard to tell if it's starting again. Besides it being such a small area,I thought white walls would help brighten things up a little.
Jack
Capn Jack
MikeMac's comments kind of echo mine. I'd never paint the Zolatone paint that hides imperfections in the hull lay-up and ding marks.
I might suggest you find a mold inhibitor chemical and wipe the boat down with that, leaving some on the walls, after washing the mold away throughly.
You can never get rid of all the mold spores, so you'll have to keep the interior dry for the most part anyway.
Instead of a mold inhibitor, you could use a Lysol (or similar) disinfectant spray, leaving a generous amount on the surface to dry and inhibit/kill any future mold growth.
Hope this helps!
Joe. :teeth
Happy Thanksgiving Joe,
Zolatone! Thanks Joe, I never knew what that stuff was called. I seem to remember it coating the concrete block wall interiors of the boys bathrooms in my elementary school. Maybe the girls were nicer, I never looked.
Mike
MIKE-
Zolatone is great stuff! Very hard and durable! Not cheap, though!
It's a mixture of two different paints that won't mix or blend, like water and oil won't mix, or are not solvent in each other.
They pour equal amounts of each in a pressure pot for spraying. Then stir them. They then look marbelized. If you've ever tried to mix an oil based enamel with a lacquer, you'd have gotten the same looking result. More stirring equals a finer mixture and particles. The pressure pot then is used to deliver the mixed paint to the spray gun thence to the surface sprayed. Looks splattered and multi-colored.
I think the formulation of Zolatone has changed because of environmental laws. Most all their finishes now are fine splattered two colored. On my older '87 CD-22 CRuiser, the pattern is slung in long blue filaments over a predominately white background. I don't see that type of pattern available in todays selection of Zolatone paints.
Cleaning up the spray gun, hoses, and pressure pot used to be a very difficult job because of the two different solvents required to cut the different paints involved. It may be simpler now. It's the volatile solvents released in spraying that the environmental regulations are trying to eiminate.
Sorry for the long speel!
Joe. :teeth
Thanks Everyone, :thup
Thanks for the input. I hadn't thought about covering up any possible problems in the hull. I used Clorox Tub & Tile cleaner, a scrub brush and warm water to clean everything. They also worked great for cleaning the anti-slip in the cockpit. When I finish I'll give all of the verticle surfaces and the "cabin" interrior a spray of Lysole as you suggested. :wink
What is the paint they use on the cockpit floors. Mine is bluish grey and is chipping off in several spots.
If you decide to paint the interior you can ask your paint supplier to add mildecide to the paint and mix it up for your. Mildecide is available at most paint supply stores I have ever used. Welcome to the C-Dory Rain Forest.....or V-Berth as it's better known as.
Also don't forget to take your cushions out and steam clean them and spray them with lyscol as well....like someone has already mentioned....those spores are everywhere.
Thanks Mike,
Love your .gif. :thup They're a lot of fun. I use Ulead and PhotoShop on photographs of mine and my friends boats.
Jack
Hi Jack,
Here on the Gulf coast stuff will mold while you look at it. If your mold returns you can get rid of it with a bit of liquid fire (bleach). Mix up a plastic spray bottle with about 20% bleach and 80% water. Spray the affected area, wait a few minutes to let the bleach do the work, and them wipe down with a wet sponge. It's cheap and works great.
I spray down the shower walls at home a few minutes before I take a shower and then wipe them down when I'm finished and it's a lot easier than getting after it with a cleaner. Around here we also bleach our houses every few years. Spray on the mixture with a garden sprayer, or hose-end sprayer, and then wash down with a hose or a pressure washer. It's a lot easier than new paint on a house.
Joe,
Thanks for the information on Zolatone. It almost makes want to find something to paint!
Mike
MikeMac":3hsdvifc said:
Joe,
Mike
You're welcome!
I just love to try to explain technical things throughly so no one can misunderstand them.
I guess you can take the old teacher out of the classroom, but you can't take the classroom out of the old teacher!
Cheers!
Joe. :teeth
Ok, so we just got our 1983 C-dory and I have to say I don't want the interior to look like someone blew their nose on it after paving. That said, I'm looking for more styley options for interior paint.
What I've found so far on the c-brats posts here ranges from specialized marine products (spendy) to Lowes on sale at $11.99 per gallon. I'm curious how these options have held up over the years.
We live in AK and so far haven't really had too many problems with condensation and no mold we've noticed. I am concerned about using toxic products because of our toddler and the possibility for one more kid at some point. As in most ventures in style we will exchange some toxicity for exquisite beauty...
Thoughts from anyone are welcome! Thanks in advance for the help!
I have just finished painting the interior of my CD22 which had lots of stains I could not remove after trying a whole bunch of solvents. I used Interlux Brightside, a 1 part epoxy paint which I have used on other boats with great results. I lightly sanded the Decraguard and applied it over the fiberglas interior as well. Use a respirator. I used white and it came out very nicely. It makes the boat look a whole lot brighter and bigger and we are very pleased.
I have used 1 3/4 qts. I have given 2 coats to the forward and middle cabins including the overhead and inside the galley. I have a little bit left to go -- the back side of the helm, the area by the helmsperson's knees, and the dinette cabinetry. I suspect that by the time I get 2 coats on that area as well, I will be slightly over 2 qts. I use an approximately 5 inch foam roller and a small paint roller tray. I also use a brush around the edges. The roller puts paint of the larger areas and goes very fast. I use the brush around the edges and in places where I cannot fit the roller. I had removed all the wiring in the boat and am completely rewiring it so painting was easier than it would be with the wiring in place.
Again, Brightside is a pretty smelly paint and I use a dual cartridge respirator to avoid breathing the fumes.
As I have sold my 1983 Classic to my son and he is coming to pick it up next week it was time to clean it up inside.
I removed every single thing that was not screwed down and scrubbed it all using Simple Green and water. Crawling up into the bow, getting into all of those little compartments etc. was a big PITA. It came out really nice and I do not think it could be improved with a coat of paint.
I did paint the outside back of the cabin a long time ago. It needs a repaint but has stayed on well IMHO. I used Pettit EasyPoxy (white) and it really improved the look of the boat. Covered up that fake wood formica look.
I have used that boat for 28 yrs. and sitting in it today I got a little sentimental about seeing it go. We have had lots of good times, good fishing and trips in it. I hope it works out for my son and his family as well as it did for us.
Hopefully I can get used to my new CD before my boating time expires. So far so good, except the fuel consumption.
At least the Classic will still be in the family so when my son moves up I could buy it back from him.
I hope C-Dory puts that on the front page of their brochures. Congratulations and best wishes to you and your son.
