Well-known member
- Joined
- Oct 30, 2006
- Messages
- 12,663
- Reaction score
- 30
- C Dory Year
- 2005
- C Dory Model
- 22 Cruiser
- Hull Identification Number
- Brat # 2202
- Vessel Name
- Sleepy-C
Another thread that has considerable about AIS and the Standard Horizon 2150.
http://www.c-brats.com/viewtopic.php?t=20861&highlight=
SleepyC:moon
HarveyThanks Bob, you have been very thorough. I do appreciate your help here. Without, I would have not had as effective system. I have been trying to avoid putting another antenna up. As it looks now, I am going to pull the splitter out from between the Ray218 VHF and AM/FM and put the 218 directly to the 8ft Commrod. Then put in the Vespar splitter between the Standard Horizon 2150 and the WatchMate AIS. That side will go to the Shakespeare 4ft that is mounted on a 24" riser, so I will continue to use a marine vhf tuned antenna there. The AM/FM will plug into the Vespar splitter on it's own dedicated bnc port and gets a receiver gain as well.
I have considered Putting the SH 2150 onto the Commrod to separate it totally from the AIS (I am using the AIS receive on it to go to the RayMarine Classic 120 - providing AIS contact points onto the plotter display.) It is also the radio I usually use for contacts other than on 16. This arrangement would eliminate the plotter AIS display pausing when the vhf is used or when the Watchmate AIS bursts are transmitted.
Another consideration: the Standard Horizon will see the active AIS transmitting from it's own position and on the same MMSI and will put that on the plotter as an AIS contact, and that will generate a "Dangerous Target" warning ..... constantly. NOT GOOD. So, the fix is in. Standard Horizon's newer 2150's have a setting to filter that signal from it's own MMSI out. The Good Part is that my (And currently any 2150 under 3 years old,) can be sent back to Standard Horizon, and they will put that filter in and activate it.
That little tidbit came from MartyK at Rodger's Marine in Portland.
So the radio has to come out and go for a trip, but it will be better for it.
SleepyC:moon
