Is it okay to store an inflated hypalon dinghy on its long side?
DaveInRI
Active member
Aug 5, 2024
213
33
Location
Narragansett Bay
2005
CDO22275K405
Once
I have a new Achilles 290 LSI, 9.5' air floor hypalon dinghy. I'd like to use it sometimes on the C-Dory and sometimes by itself on the river we live on. I have a 4' wide dock and am building a cart, modeled after a drywall panel cart, to transport it from our garage, across the street, and down the dock. The boat is 77lbs, the dock is 120' feet long (shallow river), and my back has 3 discs out and degenerative nonsense following a rear-ending car accident many years ago. Moosing it down isn't an option for me. I'd use straps to lower it down like a drawbridge rather than tilting the cart as in the second example below. I'd also make sure the high sides would be tall enough to catch the upper tubes. It's over 5' wide.
My question is whether or not I can leave the dinghy on its side, inflated, in this position inside my un-insulated garage. I know these boats are tough, but I don't know enough to answer that question. Will it hurt the boat? I'd say the most it would be on its side would be a week. The garage ceiling is already occupied with a hardtop hoist for my Jeep, so the cart would be ideal as I could put it along the back wall and still be able to park. The alternative is to lay it flat with a UV cover over it outside.
Someone made one out of Maker Pipe connections, which is another variant:
Thank you.
I spoke with a representative from Achilles who said it would be fine to leave the boat on its side. (I’d still appreciate some anecdotal counterpoints just in case)
I also asked about a spreader bar / lifting points and he said to only use the interior bow ring plus the two holes in upper corners of the transom (add eye bolts etc). He cautioned against the front exterior bow handle as being made of cast metal and more apt to break. The instructions also said not to use that for lifting. Thought I’d share that here.
I would consider that temperature changes could cause the dinghy to sag and either cause stress points from external or internal objects as it drooped over the cart and/or could drag on the ground. Might be better to store it standing on end (like they do in the local dinghy showroom).
Inflatable dinghys are often stored on transoms, with metal fittings added to the outside of one of the tubes. That would be "harder" on the storing on a platform.
You can easily add any lifting points you want. There are "D" rings with fabric (PVC or Hypalon). which glue to the boat. I have been added these for over 50 years with not a singe issue.
If you are building your own cart, you can add some support for the upper tube, if the pressure drop it wouldn’t sag too much. Been store in an uninsulated garage, you might get some drastic temperature change, especially on a sunny day, I would worry more about high temperature and high pressure then getting a little soft. If you have a 3 chamber dinghy too can release a bit of air from the bow only, that should help. unless you have a pressure relief valve, then you don’t need to worry about it.
I know a few boater that keep their inflatable sideway on the swim platform all summer long with no issues.
