Wood Zeppelin
- Joined
- Feb 9, 2016
- Messages
- 357
- Reaction score
- 0
- C Dory Year
- 1997
- C Dory Model
- 22 Angler
- Vessel Name
- C-Creature
Any reason why I shouldn't run my Honda 9.9 off of the main fuel tanks for the main motor (Honda 2021 BF100A). Currently I have to run the kicker off a separate 6 gallon tank, and dump out un-used as at the end of each season.
Could I tap into the 2nd port (unused) in the back of the water separator for a second fuel line to the kicker? Or should I not bother going thru the water separator?
Also, would running the kicker off of the main fuel tanks create an incorrect reading on my dashboard fuel gauge? (Because doesn't it get it's reading from a flow rate sensor in the main motor)? So the kicker would be using gas but the gauge would not know it?
