jennykatz":3vb9r8vp said:Why when you have 2 motors if you want a 4-6 hp for a dingy fine but a kicker ??
YOu could run one engine and put a trolling plate to slow down if thats what you have in mind for fishing etc
rogerbum":r6ltfe4z said:I might want to do the same thing. If I recall, I think Bob Austin made a board that slipped into the dive ladder mounts and was able to mount the kicker to that. Depending on how the Tomcat trolls on a single engine, I might want a kicker mounted in the center of the bracket (probably needs to be a long shaft kicker for that). Also, it would be nice if it could be steered via a remote control. I might consider looking at a solution using a generator and a bass boat like electric motor for trolling.
After I posted this - I did some looking around in Bob's photo album - here's a link to the pages showing some pictures of his kicker mounting plate.
Captains Cat":696j29ki said:Concur... But if there are trolls out there, I don't go...![]()
Doryman":3lqerw4j said:When I wanted to be able to troll very slowly with my twin 40s on the 22 or twin 150s on the Tom Cat, someone (I think it was Les at EQ) suggested that I run one motor in forward and the other in reverse. I am not sure he was serious or whether there are drawbacks to doing this, but I thought it was an interesting idea, assuming that gas consumption is not an issue. Thoughts?
Captains Cat":3vzmnc81 said:Doryman":3vzmnc81 said:When I wanted to be able to troll very slowly with my twin 40s on the 22 or twin 150s on the Tom Cat, someone (I think it was Les at EQ) suggested that I run one motor in forward and the other in reverse. I am not sure he was serious or whether there are drawbacks to doing this, but I thought it was an interesting idea, assuming that gas consumption is not an issue. Thoughts?
With the motor spacing on the TC, when I put one in forward and one in reverse, I can spin on the vertical axis. If you troll that way, you'll make the fish dizzy!
Charlie :disgust
