Kicker Relocation
Chris, Here comes that headache again. How much does your 9.9 weigh? I think my yamaha looks bigger. The high thrust is 112 lbs. Its a new 2006 model & I saw nothing in the book about mounting in anything other than as a main on a skiff.I hope the tuna come in real close this year. Vern
On page 2 of my album you can see some pics of a yamaha 15 h.p. four stroke mounted to starboard, on a mini jacker, next to a yamaha 80 main which is the physical size of the 100 h.p. Just detuned to 80 h.p. The kicker clears both the main engine and the Bennett 120 sport tabs. The tiller will barely hit the splash well wall to starboard and the main to port in a full locked turn if I don't lift it up. The kicker will turn the boat tighter than the main.
I prefer running the kicker out back in the fresh air. Not interested in the connector bar to the main. I always run with the main engine raised and as mentioned makes a great back rest. Even therapeutic when that big engine cover is warm and you cover it with a wet towel. I often sit on a boat cushion on the lazarette and steer with my left foot. When the throttle tension is set you can even control the throttle and steer with one foot. (safety lanyard around ankle) You have good visibility looking thru the cabin windows this way. I can even see the sonar at the helm thru the aft cabin window.
If both batteries are to starboard as mine are it will list slightly but it is no big deal. The boat can be leveled by moving a cooler, spare anchor or other gear. At faster speeds the trim tabs handle it. This arrangment works good especially if your swim step is already to port. I would recommend moving the batteries to port and keep the kicker to starboard if faced with the decision. But like I said I haven't felt the need to move the batteries. My bait well is used for dry storage, extra ropes and such. So, if I did move batteries up pops another problem.
Thank you Chris & Chris.Your help is greatly appreciated. C-Weed is a truely a thing of beauty & the object of my desire. It appears as though the starboard installation may well be the more common sence direction to go. I also like the laid back Huck Finn image you conjured of you with feet up lounging on the main & splash well steering with your foot. Happy days gentlemen. Vern/C-Dog
Hey C-Dog, those tuna may very well come in really close this year...........but let's face it, they're still not coming into the corner of your living room!
chris
Hey Chris. Do you have inside tuna info.? Season starts in june doesnt it? Where do you fish from? Ill be out of Cresant City,Brookings,& charleston.That was a thinly veiled slur about the proximity of tuna to the corner of my living room,but well deserved. I should have named the new boat Slow Shoes instead of C-Dog.I can use the prodding &pressure. Ill be working on the permatrim today. Its a beautiful day in the nieghborhood in the Sac. valley.Thanks for the incentive. Vern/C-Dog
Here's the skinny on running my kicker on the adjustable bracket.
The range on the bracket is only about 4". I ran the kicker in both the full up position and full down position. At half throttle the GPS indicated 4.5 MPH in both positions with no noticable change in sound or performance. Now I suppose you might be able to get the motor mounted a few inches higher on the transom without killing the impeller.
I posted a couple of more photos at the end of my album "Adding a Kicker"
I don't trailer the boat often but when I have I raise the motor on the bracket and then tilt it up and lock it in that position - same with the Honda 90.
CCFLYER,
Thanks for the info. If it were mine I'd run it at the higher setting so long as your cav plate stays under water. My johnson manual states that if you run them too deep you could cause powerhead damage from water entry into the lower engine cover. Also you're less likely to hit bottom. your pictire looks really deep at full down.
I finally got mine mounted on the port side. Had to build my own transom bracket (with about 6" lift and 6.75 inches back)but it's super strong and I have no trailering worries. It has full range of steering with the arm at about 60 degrees and the tiller arm reaches to about the top of the gunnel. I can also tie it to the main motor with a removable stainless bar. I have a short tiller extention to better control throttle.
chris
