When this recall first appeared, I checked ours and the indicator was in the green. Recently I took another look and it was slightly in the red. Thinking it would have to be recharged, I called Kidde to find out if it could be recharged. After they asked a lot of questions, they said it was eligible for a recall replacement, at no charge. So some months later ours failed after initially it was ok. Just letting you know about this so you can keep an eye on your extinguishers and not get caught with one that might not work later on. By the way, first I went to the website but could not figure out if ours fell in the recall range, so if you have a potential problem, you might have to call them for help.
