King Plastic Starboard Color
Vivire
Our C-Dory has many plastic parts both inside and out. Can anyone confirm the material is King Plastic Starboard? If Starboard, is the color Seafoam? Want to make sure were buying the right stuff for our projects!
Thank You.
At one time I also owned a 1993 C Dory 22. I don't remember any high density polyethylene board in either the interior or exterior of the boat. King Starboard is trade name/brand name. There are cheaper versions of HDPE. HDPE is a good material for cutting boards, and some surfaces. However it is not a particularly good material to use for construction. Gluing is difficult. Assembly is with screws. Paint and other coatings do not adhere to it.
"Derarguard" or Deccraguard or Decraboard (?) is a marine plywood, with an overlay of melamine or formica type of overlay which was used extensively in the building of the boats for many years. "Antique White" (#932) Formica seems to be a very close match. "Hatteras white" is close in the paint line.
Nevamar "Golden Ash #8110" has made a formica type of laminate which is a close match for the "wood grain faux teak" material in the early boats.
What is your project? What material are you trying to replace? I cannot answer your question about the "SeaFoam" color. Some places show it as an off white, others as SeaFoam green. I keep some HDPE board (Starboard) in both black and white for projects--such as an attachment for transducers for Depth finders.
Thank You.
My boat has a couple of starboard like parts on it. They are associated with the sliding reversible seat on the port side of the cabin. Only other starboard parts on my boat were after-market additions by the PO.
First, thank you for the replies. We passed along the '93 '22 to another member last year, but forgot to update the profile to reflect our '08 Venture '29 (Penguin).
The Venture '29 uses plastic with a fairly good color match to the off-white hull color. The material is used in a lid on the cockpit bench seat, the interior access cover to the bilge, and in the head cabinet.
Our boat has side air intake vents with a fiberglass insert. One piece of the insert was lost while under way. I think the best way to replace the missing piece is to make new inserts of plastic.
I have compared Seafoam Starboard to the original vent and it is a reasonable match, but not as close as the original material on the boat. I guess I'll proceed with Seafoam Star Board and see how it turns out.
Again, thanks for your comments,
Wayne
Then the "Sea Foam" would be the best bet. There are cheaper versions of the HDPE--see if they will match. You will probably want a sheet--I usually keep 1/2" and 3/4" thick for projects. If they are flat places then no worry about glue. The Cyanoacrylate adhesives can be used along with primer Permabond POP for Starboard, but I would back the joint with screws.d
We would love to see pictures of the projects as they move forward.
I ordered King Plastic Seafoam Starboard and it is a very good match to my 2008 C-Dory's gel coat.
I won't be surprised if there are lower priced alternatives. But, Starboard matches well and now I can move along with my projects.
