I was glad to see someone ask for - and you post - additional part numbers, as I was trying to figure out which Marine Beams would work for the sidelights. Thanks. But now I'm wondering if the 19 has the same light(s), because the original poster in this thread listed a different Marine Beam bulb for the anchor light....
mgarr682":29szm7qw said:
The Marinebeam TW-GE-15 ... bulb fit fine.
Lipidman":29szm7qw said:
TW GE 90 double contact base, cool white anchor.
The TW-GE-15 does say it replaces the 90... so maybe you actually got the TW-GE-15? Or else I've got something mixed up.
For the side nav lights, just to double check, do you have the Perko 120/170 style fixtures that look like this:
FS-42-30 C Green or Red $25 each
By the way, for some reason when I search that part number on Marine Beam's site, I get a completely different light, even though that
is the part number :? But it can (also) be found under "42mm/44mm Festoon LED Navigation Light Cone End Type Mini-Max"
Here is a link:
http://store.marinebeam.com/44felednaliw.html
And here is a link to the TW-GE-15 bulb:
http://store.marinebeam.com/bayonet-90- ... nment.html
