smckean (Tosca)":1w9sjl6n said:Given the low power usage of LEDs, does anyone know if it is practical to mount a local battery powered spot light with some sort of remote on/off. I suppose the problem would be the power for whatever small motor would be required to maneuver the spotlight (if anyone even makes such equipment).
On my boat I rarely need a spotlight, so the number of uses would be small, but I'd sure like to have it when I want it. I wouldn't use it enough to justify running wires and all.
ssobol":2etem8eg said:Still have to run wires for the remote so you aren't avoiding anything. Mostly I use the spot light to tell if the anchor is dragging when anchored in the dark. Point it at some landmark and you can use it to see if you drift by switching on the light and seeing if the landmark is still in the beam.
hardee":pxwj6mzs said:ssobol":pxwj6mzs said:Still have to run wires for the remote so you aren't avoiding anything. Mostly I use the spot light to tell if the anchor is dragging when anchored in the dark. Point it at some landmark and you can use it to see if you drift by switching on the light and seeing if the landmark is still in the beam.
This sounds OK until you figure in tidal currant and wind affect on the vessel. Even in good shelter, I find I get a 180 degree shift with the tidal rise and fall. That's on a mooring ball, or on anchor unless I have a stern anchor out or a shore tie. (Those two later mentions are very rare though).
gulfcoast john":1xi5q3ya said:I hated the 4 remote controlled (1 wireless) I've had...always clunky, jerky movements, difficult to aim precisely. Bulbs broke with the vibrations of trailering, LEDs were dim. The motor movements are in the base are subject to water intrusion. Warranties were short for $500-$900 lights.
My handheld LED rechargeable 'lanterns' often had non-replaceable batteries that died in 4 years.
Finally settled on this US made, 1.2 lb waterproof Larson that is very rugged and tough compared to the $59 competition (but it's $159). Way brighter than any LED fixed mount or portable light I've seen, stick it out the window to spot nav aids in the rain while avoiding bowrail glare. Heaviest coil cord I've ever seen.
https://www.larsonelectronics.com/p-171 ... ts-dc.aspx
I'll never go back to any fixed mount with the hassles of threading 8 conductor cables through and out the railings.
Works great for us, but we avoid boating at night.
A compromise to consider, though. Buy quality the first time, and you'll never be dissappointed.
Cheers!
starcrafttom":s5tls7yr said:It's funny that one person can want one thing for a reason but another does not want it for the exact opposite reason. I tried the hand held spot lights and found then useless for anything other then looking out the side at a 90 degree to the boat. I could never hold my hand far enough out the window to not get glare off the anchor and bow rail when looking forward. Not to mention the only having one hand to drive while sticking my hand and some times head out the window. ....
its just funny that I got a rail light because of the problems of a hand held and you got a hand held because of the problems of a mounted light. Just goes to show that there is no perfect solution to any problem.
