Well-known member
- Joined
- Nov 2, 2003
- Messages
- 21,963
- Reaction score
- 298
- C Dory Year
- 2007
- C Dory Model
- 25 Cruiser
- Hull Identification Number
- DOR25652A707
- Vessel Name
- thataway
The post about light bulbs and fuses motivated me to check and see what I have on "Thataway" (Almost identical on Frequent Sea) Perhaps others can add what they carry, or it will help newer folks to know what to take aboard.
Light bulbs: One bulb for each type of fixture, include nav lights, fastoon for the cockpit lights. (we are changing over to LED's) Also I keep a cig plug Davis all around light which has two brightness bulbs, plus a set of dinghy LED battery operated running lights: Red/Green plus 360 white aboard.
Fuses: ATC 3 boxes from 2.5 to 30 amps, ATM two boxes, round glass assorted two boxes, plus specifics for each of the electronics. Plus one each of the circuit breaker types on the C Dory, and an extra 60 amp breaker.
Crimp fittings for all sizes wire and terminals, including spade and round, plus 3 way and spade 1 to 2 adaptors.(about 80 pieces) Ratchet crimpers, heat shrink tubing, dielectric silicone gel, a butane soldering torch, along with resin core solder and 5 different tips: soldering two sizes, hot air and cutting.
Also electrical tape, self fusing (rescue) tape, Gorilla Duct tape. tube of Silicone clear, 4200 one tube, Loctite, medium, JB weld Kwick, 5 min clear epoxy, MarineTex, Permatex Form-a-gasket soft, rubber and cork sheet gasket material. (I leave the liquid tape at home) Also carry a few support clips for wiring bundles and grommets for wires thru glass bulkheads.
Zip ties, monel sizing wire, extra shackles from 3/16 to 3/8", extra 1/8" dacron line. Also several hanks of extra 1/4" line. Pipe, thread sealant, and Teflon plumbers tape. Two pair of Nitrile gloves.
Sewing kit: lock stitch awl, with #150 coarse dacron waxed thread, a small bobbin of VE 92 dacron thread, plus sail making needles and sailor's palm, 2" Sunbrella binding tape to match the green of the camper back.
Hose clamps for all sizes of hoses on the boat (fuel stove, water and drainage systems.) Hose barbs for the fuel lines and water lines, to include pipe thread and BST fittings to the barbs.
3/16 and 1/4" cable swages, Canvas snaps, and a hand (hammer) set die.
Bolts from #8 to 3/8, in lengths from 3/4" to 4" with washers, lock washers nuts and a few finish washers and nylon washers. Screws from #6 to $12 in 3/8 to 2" lengths. Set screws (allen head)
Tools:
Socket set from 1/4" to 1/2" drive, with a 1/2 to 3/4 adaptor for those sockets from 1. 25 to 1.5" (including one to fit prop nut). Prop nut tool/wrench. Open end and box wrenches of appropiate size. Torque wrench 18" 1/2" drive.
Impact wrench with 1/2" drive--and flat/phillips screw bits--hand hammer driven. Spark plug wrench
Ball Peen hammer, Set of vise grips--round and long nose, medium an small, large round nose. Chain and clamp vise grips. Water pump pliers large (channel locs), 14" pipe wrench, monkey wrench. 6" 8" and 12" crescent wrenches. Allen keys--metric and SAE to 1/2".
Cup wrench for the oil filter on the outboard (1/2" drive) plus a strap wrench.
Pliers , round nose, Diagonal cutters, Long nose pliers, cured and straight, plus split ring and crimp fishing pliers. forceps(long and short) fine tweezers. Magnifier (often carry 2x/4x loop)
Digital volt meter, 12 volt test light, several jumper cables with alligator clips for testing, 110 volt circuit tracer, 110 v 15 amp plug polarity tester. IR thermometer, mechanics mirror, machinists rule, Vernier calliper, with depth guage. Magnetic pick up and "grabber" Heavy duty Jumper cables for other boat's battery loss.
Screwdrivers from Jewlers to 1/2" flat tip, and large phillips, plus Robertson (square) and Torx bits. scissors, hand labeler (for wiring and location of gear)
Hack saw blades and short handle. Files: swiss needle files, mill file, rat tail fine and coarse files and 4 in hand rasp/ file. Sand paper and emery paper. Wire brushes--SS and brass. Drift punch (3/16"), taper punch, center punch and 3/8" cold chisel
Hand drill and set of bitts to 1/4". 7.2 volt rechargable Dremel tool with a set of bits, grind stones, and cut off wheels, polishing wheels etc.
Before someone says--where is the "other boat" you tow to put all of this stuff in--here is how it stows.
The socket set and open end wrench/box werench are on one fitted case. There is an 18 " canvas heavy duty tool bag with most of the larger tools. There is a single packet for volt meter, IR thermometer, Calipers, rule and tape measure, plus a packet for screw drivers, and plier/vise grips.
the Dremel tool is in a bag, plus a small box of accessories. The bulbs and fuses are in one small Plano tackle box. The screws, crimp fitting ties ets are in a medium two sided Plano Box which sits outside of the Freezer/refigrater--along side a tackle box with lures). The tubes of glue and sealant are double bagged in the back of a locker. 90% of what I use are in one pouch, which has a small 1/4" drive socket, screwdrive bit set, plus pouch with vise grips, and screwdrivers.
You don't want to know what we carried on our ocean crossing boats, but we could basically build almost anything we needed...
Tools:
