I appreciate the feedback. I took a look at your boats...very nice. I will be refering to some of your photos when outfitting my boat. I am continually amazed at the creativity of C-Dory owners when it comes to outfitting their boats. It's too bad, I lived in Malibu for 15 years, and always wanted a C-Dory to take out to the islands and to trailer down to Baja. Always had the dream of cruising down around the cape and then back up the Sea of Cortez. Could never afford to buy one then with the mortgage on my home in Malibu and all. Probably would have gotten to get together with you guys. Oh well, now I'm stuck in Hawaii, and will just have to make the best of it now that I've got my boat. Roger, I liked your set-up. Would like to know what mounting brackets you used to secure it. Have you found that it helps deflect some of the water over the transom when your hit from behind? Have you thought about putting some matching material to finish sealing the area off to better serve that purpose? That would make a great base for a cleaning station or serving table. I'm still trying to decide whether or not I want to put my live well there vs. a fish box/cleaning station.
Don, I was thinking about using the lazarette as a live well, should I decide to put my fish box on the transom. It appears that my lazarette has a hole in the bottom for either a drain or pump hose. Did your dealer even use that? Is your friend happy with his lazarette set-up? As far as the size of the thing goes, we typically catch our own bait over here with a handline, and usually may only carry maybe a dozen baits at a time, although our baits are a bit larger than sardines.
Thaks,
Bill Showalter
