Long, narrow flexible solar panels
kennharriet
Jan 22, 2009
589
21
1999
Lochsa
I am researching narrow, long, flexible solar panels that would fit on the side brow of a CD25. The available real estate is about 12”-15” x 60”. I have seen some that seem to fit on a Tomcat and also on a 25. Any thoughts on a source? Thanks, Ken
Rich Solar makes a CIGS 80 watt panel that I was able to fit on the sides of my 22' cruiser. I had to cut a 1/2 inch taper along the side to make it fit using a hot knife. Luckily there is enough "empty" space to do that without damaging the solar collection. I also mounted the panels on 4 mm corrugated plastic to allow air circulation and better cooling. I also have a 200watt panel on the top.
I bought a 110w unit (SunPower) from Mr. Bezos' company.
Localboy; Can you post pictures of the fit, please? I'm opting for this and want to get a good fit. 220w vs 160w seems desirable. Thanks.
The panel is about 45”L x 22”W but it fits across the cabin top.
Zamp and Sunflare make narrow panels close to that size.
View attachment 132091View attachment 132092
Very nice clean install.
I attached mine with YKK Snad fasteners. The female off-white fastener sticks to the cabin roof. I then bought some male fasteners that inserted through each grommet hole on the flexible panel. That spaced the fasteners such that the panel sat 1/2" above the cabin surface for an air space. They are removable, which could be a theft problem for some, although I doubt most thieves would think that the panels are "snap-on."
That sounds like a good mounting option. Is it secure enough for highway travel or do you remove?
That will probably work for me then, except when traveling through Canada at kph. 🙂. I’ll get some ordered.
