pcg
- Joined
- Aug 31, 2018
- Messages
- 456
- Reaction score
- 14
- C Dory Year
- 1999
- C Dory Model
- 22 Cruiser
- Hull Identification Number
- DOR22866J999
I’ve had plenty of time to think through the helm design for my 22’ Cruiser restoration and would like to offer it up for criticism before I start modifying the fiberglass at the helm. Keep in mind that I’m an engineering nerd so there will likely be things about this design you don’t like and that’s expected. However, I’m looking for mistakes, or things I’ve overlooked. I’m new to this and I very much value the opinions of the experienced C-Dory captains here.
Referring to the photos below, the first photo shows the complete helm, but somewhere along the way it gets resized so that it's not possible to read switch labels. To remedy this I broke the drawing into upper and lower portions, and hopefully the switch labels are readable if you zoom in.
Navigation and steering aids are on top, beginning with Garmin chart plotter that sits on top of the helm, with room for an iPad to the right. Above the steering wheel, from left to right, are the autopilot display, a small display for engine gauges (can be an iPhone running an app), a simple depth gauge, and a controller for Dometic trim tabs. Below and to the right of the trim tab controller is a 12V outlet (can hold two USB ports) and the cable for the wired windlass remote.
Non-navigation items on lower left are the heater thermostat, and ON/Off switches for the propane solenoid, heater, fridge, fresh water pump, wash down pump, and a switch reserved for future use (maybe a watermaker).
Non-navigation items on lower right are the controls and breakers for the AC circuitry. Below that are breakers controlling items that need to be turned off in the event of a BMS alarm (house batteries are LiFePO4). In the event of a BMS alarm (which sounds 30 sec before the house batteries shut down) the solar panels and DC charger need to be disconnected and all devices normally powered by the house battery are switched to the start battery.
Non-navigation items to the right of the AC circuitry panels are DC on/off switches for the horn, wipers, radios/AIS, chart plotter, radar, autopilot, trim tabs, nav lights, bow light, windlass, security alarm, and bilge pumps.
Also, I know many of you don't like propane, or prefer trim tabs other than Dometic, or think a BMS alarm is overkill, or whatever. That's fine, but that's water under the bridge and not what this post is about. I'm interested in feedback on my helm design.
I know this is a LOT to ask and most of you are probably rolling your eyes at my request, but for those of you with time on your hands who like to find something wrong with someone else’s design, please fire away. I thrive on negative feedback!
What would you change? What have I missed? Thank you!
