Project: Give the Jenny B fuel flow measurement capability
Since, IMHO, the Navman 3100 is too big for my C-22 helm station and all Navman fuel flow meters are tough to get, I chose to experiment with the Lowrance LMF-200 multifunction gauge and fuel flow sensor package. ($149 complete) and attempt to integrate it with the Raymarine C80 Seatalk2 system.
This is complete NMEA 2000 system for 150 smacks!! It includes termination resistors, two "T"'s, a 12 ft. extension cable, the alarm and the DC cord. It WILL NOT WORK in NMEA 182 environments but it is definitely a stand alone flow meter. One would be horribly underutilizing it's capabilities which are, in fact, more than what the Navman is capable of.
Installing the gauge is a snap. Requires a 2 1/8" hole saw and the entire meter is 2 3/8" in diameter. Installing the fuel sensor is just as easy, with the caveat that the sensor arrow must point directly up and must be installed after a good fuel filter.
The sensor lead is long enough to reach just about to the rear of the helm seat cabinet and that's where I put the first "T", then the extension cable. (way too long) was fed up behind the dash to a second "T" which has the other termination resistor and power cord. I tapped both dash light power and NEMA 2000 power from the ignition wire.
Here's where more parts are needed. 2 ft. LowranceNet extension cable and a third "T". Both are carried at Cabalas and Lowrance direct. The second T screws into the first T and the extention cord goes to the Raymarine C80 Seatalk2 socket.
Oops, there are no existing adapters from LowranceNet to Seatalk2. You must also purchase a Seatalk2 cable that fits the C80, cut the cables and splice the Seatalk plug to the Lowrance plug. Easy done since both cables use the same color code: Blue/white data, red/black 12vDC/ground and the shield ground.
IT WORKS
Static tests show fuel flow both on the C-80 AND the LM200. Also shows position on the LM200, and if it does that, the LM200 is also getting speed etc., from the C80
There are some minor glitches not covered by the manuals, such as one has to disable the Seatalk2 alarm in C-80 setup and make sure to search for and configure the fuel flow sensor plus set the LM200 timeout to 10 seconds if you're old and slow, but so far I get valid fuel flow readings on the C80 and my LM200 is set for two displays: Fuel flow and MPG. Enough for a start!
The learning curve is slow for me but the potential is well worth the effort. Lowrance has a winner as does Raymarine. OBTW, ETEC engines can also be interfaced to the NMEA 2000 bus. I wonder if Yamaha's can?
Added trivia: Raymarine Seatalk2 and LowranceNet are both simply NMEA2000 bus with proprietary connectors.
My next project is to get the fuel flow data to appear up in the C80 data bar rather than on the engine data page. Prolly need to contact Raymarine on that one and their tech support is still struggling with the fact that the C80 is NMEA 2000 capable....
Don
IT WORKS
Don
