Beartrack
- Joined
- Jun 11, 2007
- Messages
- 55
- Reaction score
- 0
- C Dory Year
- 2001
- C Dory Model
- 22 Cruiser
We took the 22 C-Dory with the 2001 80-hp Yamaha out for it's maiden (to us) voyage yesterday after back flushing the carbs, replacing / upgrading the fuel-water separator, replacing the fuel filter, and installing new batteries.
Unfortunately the trip didn't go so well - good thing we had just picked up a backup kicker motor the night before! We made it from the moorage down the river about a mile and had to turn around and come right back. The main 80 hp Yamaha 2001 motor never did come up off of running on just 2 carbs (or at least 2 cylinders) apparently after trying to run it for about 15 minutes at 1300 to 2100 RPMs. It ran very rough at pretty much all RPMs, then when I tried to push it above 3k it backfired once or wouldn't stay running so I stopped trying, switched to the kicker and drove that back to the dock.
Also, though I couldn't tell for 100% certain, the charge seemed to have dropped on the 1 battery that was turned on at the marine dial switch rather than have stayed/gone up in charge - to the point it wouldn't restart the main motor actually after having accidentally just left the key in the wrong position for 15 minutes while running the kicker. So I'm guessing the 80hp Yamaho also is not charging the batteries either. Anyone have any ideas?
Reading the Clymer Yamaha Outboard Shop Manual last night until 3:00 a.m. and again this morning, sounds like it could be any number of things that could keep 2 cylinders from either getting the right gas or firing correctly:
1) electrothermal valve not warming up;
2)battery charging coil or rectifier/regulator not getting the right voltage to the sytems and thus not warming the electrothermal valve,
3) the ECU having a prob - and thus not signalling the 2nd 2 cylinders to come on,
4) the engine temperature sensor;
5) 1 of the 2 crankshaft position sensors not getting a reading;
6) some fuel system problem I've missed resulting in not enough fuel and what I think is 2 cylinders not firing is just all 4 running roughly; or
7) Carbs out of synch badly
8) some other problem that as a newbie I've missed.
I've worked some on off-road vehicle fab in my past, and occasionally on older cars, but this whole outboard things is a new adventure for me; I've never done it and all I know is pretty much what's in the shop manual here.
Have to say, it sure was a bummer of a maiden voyage for my wife, daughters and even the dog yesterday but I'm hoping to get this fixed and working ASAP. Any pointers, ideas, thoughts - or even things to avoid - would be hugely appreciated!!! Thanks gang. Also, according to the Shop Manual, looks like I would need several custom wiring harnesses from Yamaha to test some of these parts; anyone here ever used them / owned them and are they something I could easily fabricate myself and/or are they expensive to purchase from Yamaha?
Thanks again folks, really could use some help on this...
Beartrack
Beartrack
