Thanks Warren. Sure that will work. Not as neat as adding a one page file as an attachment but ....... Here it all is. Still a work in progress.
RANGER R-25 CHECKLISTS
Version 3.1, 6/18/07, RAS
BEFORE TOWING
1. Inside
a. No loose items
b. Cabinet doors closed
c. Fridge door secure
d. All switches off
e. Batteries off
f. Windows / hatches closed
2. Salon door locked
3. Battery main and inverter off
4. VHF antennae down/locked
5. Transom gate latch taped shut
6. Straps secure
7. Drain plug in
8. Ladder up
9. Tires / bearings okay
10. Hook-up complete
11. Lights checked
BEFORE LAUNCHING
1. Weather forecast okay
2. Launch ramp okay
3. Adequate fuel / water
4. Hydraulic fluid level okay
5. Thru hulls open (3)
6. Sea water filter clean
7. Bilge clean
8. Salon door open
9. Fenders / lines in place
10. Straps off
11. Electrical unhooked
12. Ladder up
13. DRAIN PLUG IN
14. Tailgate down
15. Truck in 4-wheel
BEFORE STARTING ENGINE
1. Main battery switch on
2. Inverter switch on
3. Battery switches on
4. Throttle idle
BEFORE LEAVING DOCK
1. Dinghy secure
2. Oil pressure normal, cooling water
from exhaust, alternator functioning,
engine temp okay
3. HULL
a. All hatches and ports closed.
b. Trailer pigtail inside
c. VHF antennae up and locked
4. ELECTRICAL
a. AC switches off
b. DC switches
(1) GPS/chartplotter on
(2) Depth sounder on
(3) Autopilot on
(4) Trim tabs on
(5) Water pressure on
(6) Fridge on
c. Chartplotter set
d. Windlass master switch on
e. Radio on
5. Shore power cord off
6. Thrusters on and checked
7. Rudder centered
8. Current, wind, traffic checked
9. Retrieve dock lines
AT THE DOCK
1. Secure dock lines
2. Adjust fenders as appropriate
3. Turn off instruments / radio
4. Connect AC power line
5. Electrical
a. Check polarity / master on
b. Switches on:
(1) Inverter
(2) Fridge
(3) Battery charger
(4) Hot water
(5) AC outlets
c. Turn off DC circuits not in use
6. CHECK ENGINE OIL 10 MINUTES
AFTER SHUTDOWN
BEFORE TOWING
1. Inside
a. No loose items
d. All switches off
e. Batteries off
6. Straps secure
7. Drain plug in
8. Ladder up
11. Lights checked
BEFORE LAUNCHING
2. Launch ramp okay
7. Bilge clean
8. Salon door open
10. Straps off
12. Ladder up
13. DRAIN PLUG IN
14. Tailgate down
4. Throttle idle
BEFORE LEAVING DOCK
1. Dinghy secure
engine temp okay
3. HULL
4. ELECTRICAL
a. AC switches off
b. DC switches
(3) Autopilot on
(4) Trim tabs on
(6) Fridge on
c. Chartplotter set
e. Radio on
7. Rudder centered
AT THE DOCK
5. Electrical
b. Switches on:
(1) Inverter
(2) Fridge
(3) Battery charger
(4) Hot water
(5) AC outlets
AFTER SHUTDOWN
