Les Lampman
Greetings,
Thought I'd pop in and give anyone interested an update on the Marinaut scene.
We've got one boat building in the shop right now. I've been posting infrequent photos on Facebook since we've been loafing along (lots of other things happening as well). It's looking really nice though and it will be exciting to see it when it's completed.
I'm leaving on March 28th (that's the plan anyway) on a road trip that will take me to Connecticut with the Marinaut Betty Ann in tow. The plan is to drop down to SLC and then take I-80 across to around IL then drop down to I-70 so that I can make a stop in PA. I also have the alternate routes of I-90 or I-94. If someone along any of these routes really has an interest in the Marinaut 215 I can try and accommodate a stop.
After dropping off the M215 in CT I'll be traveling to Halifax to pick up a new (sold) Rosborough RF-246 then returning to WA.
Also...the drawings for the M245 are just about completed so I'll soon be adding that to our Marinaut web page and making the boat available. Some folks might have seen the drawings I posted on the Marinaut Facebook page. Those drawings showed a pair of engines on the transom but I've decided that (at least in the beginning) that the M245 will be offered with a smaller motorwell for single engines. I very much want to have a transom door (entry) in the aft starboard corner just above the swim step/ladder and I can't do that with a wide motorwell. I'm betting the walk-though transom will be more important to most buyers than accommodating twin engines will be.
Another issue with the twin engine set up is there's really only one choice of engine size and that's a pair of 90's. The engine manufacturers don't make 75s with 25" shaft and 115s (the next size up) are too heavy and too much power.
Another potential issue is cost. A single 150 (which is the target horsepower) is about $14,000 fully installed (controls, gauges, batteries, etc). A pair of 90's is about $20,000. That's a lot of difference even if you add a kicker to the 150.
Weight is also a consideration. A single 150 is about 500 pounds, a kicker about 100 for a total of 600 pounds. A pair of 90s is about 800 pounds.
And finally, the last issue is space. Not just at the transom but the space it takes to accommodate twins at the helm with the need for two controllers and additional space on the dash panel for more gauges.
The primary thing for me is I want the easy access at the transom from the swim step so using a dinghy isn't fraught with peril for those of us that are not as athletic as we once were. And I can't do that with a twin engine motorwell; the other issues just serve to reinforce my decision.
That's all for now...thanks!
