Well-known member
- Joined
- Nov 2, 2003
- Messages
- 21,936
- Reaction score
- 284
- C Dory Year
- 2007
- C Dory Model
- 25 Cruiser
- Hull Identification Number
- DOR25652A707
- Vessel Name
- thataway
Hi Brent,
We discussed this. Ricardo will be using a hull laminator who he has worked with before initially. The shop is all set up--and making the mold parts maybe takes a week, if that is all they do--set up, polishing and waxing the mold, setting up the laminate schedule, and I assume resin infusion,, with coring, assuming no new molds are necessary (for example we discussed a full upper inner liner of smooth fiberglass, with some insulation between for the hotter Florida climates).
Then the hull is pulled from the mold, The parts are set together and tabbed/glassed together. (actually best done if the boat hull is still in the mold for stability) Cutouts done. Windows placed (may be changes there), hatches fittings etc. Then wiring, and finish work. With 4 people working that could be done in a a month, IF they had everything on hand, and knew exactly what was needed. With a new boat and new suppliers, there could be significant delays. There is wooden trim, which has to be hand made, and then fitted etc. Upholstery, instrumentation if the boat is rigged at the factory etc. I think that if they got the first boat done in 3 to 4 months, it would be good time!
I believe that Les was having the hulls molded off site (I don't remember the jobber, but they normally did larger vessels, and worked the Marinaut in between other jobs.) Then Les brought the hull and deck to their shop to do the finish work. The first boat takes far longer than each subsequent boat. as I recollect Ricardo felt that one boat a month was a good starting point, then 2, 3 and finally 4. Not a huge operation, and only one model to start. Makes sense, rather than tie up a lot of capitol in trying to do a number of models. Dave may correct this. I had talked with Les about making a 25 back a few years ago.
