Minks in my C Dory!
uvicgrad85
Feb 11, 2009
36
2005
16 Cruiser
Does anyone have any good advice on how to keep minks out of my C Dory?
It is stored in a boathouse on fresh water. There is never any food on board.
I removed 3 babies that got in over the last couple of days. Fortunately the damage / stink wasn't too bad.
Momma mink got her babies back after I pulled the boat out of the water and cleaned it up in the driveway. Next time, I may not be as nice.
:twisted:
Good morning from Iowa,
We have never had Minks, however as fall and winter comes on rodents do try to come inside out buildings.
Maybe it’s an “old wives tail” but we make little cups of tin foil filled with moth balls which are placed randomly inside the building and one or two inside the boat.
Works very well, no rodents, worth a try might work for Minks.
Regards,
Ron Fisher
<stuff clipped>
Just leave a coyote on board. :wink:
Me thinks, you need a wife with simpler tastes...
Come on, y'all - this guy was kind enough to lob us a slow one, right over the plate. There have to be at least a dozen more smart-a$$ responses.
A more useful response would be apprecitiated.....
8)
But not nearly as fun.....
:roll:
I was worried about critters getting aboard also, I plugged the 2 holes where hoses and cables come into the cabin with foam. I thought about using those stainless steel dish scrubbers jammed in there also. That worked on a rat problem in an old house I had once. Critters don't like to gnaw steel. I'd go that route with a known problem. The rest of the cabin is pretty tight but those two holes would let them in. Good luck George
Last year I had a bear get in the boat. The solution to that was raise the swim step so it was at least harder to get in, scare the bejesus out of the the bear and owner, and move the shotgun closer. My wife has never wanted to wear the mink in the boat so that hasn't been an issue.
Just how does a mink get in the boat?
Don't you mean you want advice on how to GET minx onto your C-Dory? Oh wait a minute, you're referring to the other kind.
Ha ha - sorry that was a lay up!
Bottom line will be a cover to prevent it. Perhaps others can suggest other remedies.
Put fly paper where they enter. It works with raccoons.
The moth balls in cups idea has worked for us.
You can leave it at my house, we are certified mink free. No charge for this selfless offer, so don't insult me by offering money!
The fly paper just might work. I made a duct tape minefield to train the neighborhood cats to stay off of my Jeep seats.
As previously posted, moth balls are a good idea.
They have worked for me with various & sundry pests.
Steel wool works nicely, as almost no critter will chew through it. If you find a hole anywhere fill it with steel wool. Neither mice nor minks...
There is also the option of going with the sticky paper that catches mice, but ONLY if you want to kill whatever gets caught on the paper. I've always considered that method to be rather inhumane, but would employ it before allowing any critters to damage C-Gypsy!
They work for squirrels when they are baited with peanut butter, but be sure the moose can't reach them.
There's nothing worse than a crazed cow moose running around with a rat trap on her tongue.
Perhaps boing on the net and contacting a minx farmer would yield some useful info. After all, they are usually able to keep their minx confned.
