spuncopper
Hey gang,
I purchased a Moeller 6 Gal. Topside Gas Tank a few months back. The first couple of times I used it the weather was in 80's with water temp in the 70's.
This past week, we went out in the morning and everything was fine. On the way back in the air temp. was 100-101 degrees F and the surface water temp. was 92 degrees F.
We were on plane and the engine (2007 Suzuki DF 50) suddenly shut down. It re-started but died as soon as I tried to go on plane. Started checking fuel connection and discovered the Moeller Tank looked like a fat sausage. Opened the cap and relieved the pressure, checked to make sure the vent was open, as per Moeller instructions. Started engine, put it in gear and it died. Shifted to the 6 gal. Suzuki tank, started engine and let it fast idle for a few minutes and came on home.
When I got home, the Moeller tank, once again, looked like a sausage. Went on line and found a number of the same complaints I had. Has any of the C-Brats had this problem?
Thanks!
Thanks!
