Hello,
We recently purchased a Caper Cruiser 23', and are trying to get it prepped for the upcoming fishing season. We purchased Burnewiin Mounts to place on the gunnels. My questions are:
1. When drilling the 4 screw holes for the gunnel mount. Should I be using the technique where I drill a larger hole, fill with epoxy, and then drilling the correct size hole for the hardware?
2. When using the hole saw, there will obviously be a hole left in the gunnel. Should I be applying silicone to the hole that is left before inserting the mount?
This is our first balsa cored boat, so i am wanting to make sure everything is done correctly the first time.
