AstoriaDave
Sunbeam wrote:
Okay, so if all the wiring on the "other" side of my equation is #6… that seems like it is plenty good for a larger-than-30-amp fuse. But….I only have 10 gauge running from the positive bus up to the helm panel (and that is wire that came with the boat, so probably nothing special in the quality department). However now I'm getting confused Embarassed I now think I know that all the individual fuses (mentioned in my list) protect the "small" wires running from the components to the fuse block (behind the helm), or the switches (by the helm). But does the 30 amp main fuse protect the "other" wires "behind" it (house battery/ACR/Safety Hub/main switch in lazarette, all #6 wire), OR does it protect that "supply" wire running from the positive bus to the helm area? I should be able to figure this out but…. maybe my brain has too small a fuse tonight
Diagram this all out and it will make more sense. Sounds like the fuse should protect just the run from the battery TO the buss bar/fuse block behind the helm, #6 all the way, yes? Other runs off the same battery terminal, perhaps passing through a switch, should have their own fuses, if that is what you are describing. I don't know what loads you can expect to those other items, so wire size and fuse will need to be selected accordingly.
