Need help for slipping rod holders
drjohn71a
Jul 15, 2004
1,820
2007
255 Tomcat
Tom-a-Hawk
'Finally got my Perko, clamp-on rod holders partially installed. I got the 1 1/4 inch models for the TomCat, but am finding they tend to slip around, especially when under way. Putting the little Magna Newport grill or the smaller Magna tables into the holders only magnifies the problem.
I tried loosening them and putting non-slip strips under the clamps, but they still tend to slip and work loose.
Does anyone have a good way to stop the loosening of clamp-on rod holders?
John, Its a little invasive but you might consider drilling and using a set screw.
Russ.... thanks, but... Ouch! I'm wondering if they have a stainless version of those perf strips they use to hold old chair leg dowels in place.
I was thinking of welding... then I could grind/file/polish back if I moved something.
Did you glue the "non skid" material to the SS railing? We found that works for us for some things which "slip".
Bob, I bought those thin, glued strips - maybe 5/8 inch wide. They work OK until they get hot. My main problem is the long leverage from the Magna rod-holder adaptors for the white shelves and the Newport grill.
John – can they be mounted next to an upright support, then make something to attach to the upright to keep it from slipping.
________
Dave, thanks, that sounds like it could be done without damaging the current rails... I'll have to do some catalog digging for stainless fittings. It's going to be difficult to hook something up that maintains the desired rod angles, though.
