Need help YAMAHA 50 hp part identification
KevinDU
Dec 10, 2010
96
1
2007
Sea Otter
I found the same loose part in the bottom of the other engine, just below the air intake. Motors are running fine, should I be worried about it? I can't figure out where this plastic piece was attached.
Did you check the hood itself?
I have no idea what that strip is, but those 2 tits are fasteners into 2 holes. look over the hood and engine compartment until you find the matching holes.
I realize you probably already did this. I have to make some comment.
Oops, I had said to go to brownspoint.com to look at a parts diagram. I now realize that they only specialize in Suzuki parts. If I come across a Yamaha parts dealer I will let you know. Looking at a parts diagram should help you to determine where that component came from. I would start by looking at Yamaha parts dealers on-line to remedy this problem.
6C5-42718-00-00 Google this yamaha part# it will be # 8 in the pict
Thanks, tsturm! I found a parts diagram and will look into it tomorrow.
