Well-known member
- Joined
- Nov 2, 2003
- Messages
- 21,897
- Reaction score
- 239
- C Dory Year
- 2007
- C Dory Model
- 25 Cruiser
- Hull Identification Number
- DOR25652A707
- Vessel Name
- thataway
One of the issues with trailers, is that the rated capacity is often the trailer and boat. So be sure that you are getting a trailer big enough. 8700 should be OK. But if you get a 6500 # trailer, then it will likely be too light duty.
If you are going to do any boating in Canada or going up or down mountains, then get Electric over hydraulic brakes. For example British Columbia will not allow trailers over 6,173lbs to have surge brakes (Brakes must be capable of application from the towing vehicle cab).
Any price under $4,000 is a good buy, but a lot depends on features on the trailer. You can get tandem axle trailers with capacity well over 10,000 lbs. There are common setups rated for 12,000 lbs.
