New Anchor
AKMel
Jan 13, 2017
57
3
2008
C-esta
Thought I'd post my new anchor. First, I got it for my 20' enclosed Alumaweld fishing boat, but can transfer to the Cdory as needed. I will need to change the Cdory to a 2.5" wide bow roller if installed as other than a throw-over the side. Up here in SE Alaska there are a lot of large sharp rocks in the seabed. My old forstner anchor was terribly beat up and bent up. I was waiting until I lost it, but instead it would bend and finally pull free, but then I needed a large hammer to put it back in workable shape. That was something I couldn't do on the water. time of something better. I have many friends who have lost multiple anchors, and have seen yachts going in circles trying to break their anchor loose. Enuf said. Name of the new anchor is "Breakaway." It's a plow style, but different in that it has a resettable system. So pretty it makes my boat look bad. I got the smallest, 21". I was anchored for halibut last week during a 7 knot 16' tide. I was watching for movement on the gps but the anchor held fine. My old anchor wouldn't have held. In another anchor-up the anchor got trapped and did what it was designed to do. The chain broke away from the stem and pulled the anchor free via the plow end. The beauty was resetting the chain took 30 seconds or less. It's listed on Amazon but I had to contact the company for the 21".
Is this the anchor you purchased?
If so there are a number of other anchors which work the same way, and may have better holding in all conditions, including sand and mud, where this type of achor does not work as well.
Any plow or even Danforth/Fortress type can have a line or the chain attatched to the crown of the anchor, and zip ties holding this chain down on the stock of the anchor, until the pull is reversed 180 degrees, to pull it out when stuck. Some Plow or spade type have either a slot cut in the shank, or an attatchment point in the crown.
In some anchorages where the anchor is easily fouled, and difficult to weigh--I have used a separate trip line, with a float labled, "Trip" ir similar, so someone does not grab it thinking that it is a mooring.
Bob is spot on here... see how the ring on this particular anchor is designed to slide up to the crown when you pull the opposite direction if it's stuck? Good stuff! 😉👍
IMO, a trip line is better than a slot or zip ties. If the boat swings or the ties break (they can get brittle in UV light) you can end up pulling on the anchor the wrong way and unsetting it. Murphy's Law says this will happen at the worst time possible.
https://breakawayanchor.com/ A pretty anchor- stainless, very sexy and expensive!!! However, I must agree with ssobol (and Murphy) ; If it can happen sooner or later it will happen —probably at the worst possible time!
The "Breakaway" I got is plow style. Sorry if you took my post as a tutorial that there are breakaway anchors out there, though I'm sure your posts may help someone in the future. Rather thought I'd share it as a new breakaway system that is available. I've used it for a while now, and the beauty of it is the ability to reset the breakaway quickly. Works with the reliability of a plow style anchor. No problems if it got stuck. It didn't come with instructions and I gradually learned how tight to tension the breakaway device. If you click on the pix it shows the pix full size with bronze fitting at the top of the stem. Blessings.
How hard of a pull does it need for the system to break free? From your last post, seems like that may be user adjustable, am I reading that right? Also, would that have the potential to wear overtime? Seems like a good idea over the zip tie for people that like to rig their anchor that way but I still prefer having my anchor attach at the very end of the shark only, and using a trip line if I feel the need, That is my personal preference but I understand why some people like it. At that price, I could loose a couple anchor and still be ahead, just kidding, loosing an anchor is more then just the replacement cost.
I'm learning more about anchoring from this thread. Right, the amount of pull needed is adjustable. There isn't a dial or indicator lines, one has to set the torque by feel. I had the same question about wear on the apparatus. I've experienced break away multiple times due to rocky bottom in our area. I looked for wear on the break-away feature, but haven't seen any so far. I assume there will eventually be some, but the adjustability should compensate for wear. There are thousands of miles of inside passage by us, most of it with rocky shoreline. We often anchor out overnight. With their system, if set right, seems to me there is no danger of an anchor pulling at night like if a zip tie broke, and the boat drift into some damaging hazard. That insurance is worth a few $ to me.
Does it have any give in that system like a spring or some flex, or is it just bare friction SS to SS. I couldn’t find any details on that in the advertisements.
C-Wolfe: No flex in the actual breakaway system that I can see, unless you consider flex in the line to the anchor. The system is friction. It's two parts. One component seems to be bronze. The shaft component is a gray metal, not sure what. No scale or corrosion on either part after using in salt water so everything seems to be marine grade.
