New battery placement on a 19
South of Heaven
Aug 15, 2015
1,458
Guys, currently my 19 has one battery and it's located on the starboard side in the gunnel box. I'm gonna be replacing that battery and also adding a second battery (house) for my new electronics.
My question is this: Initially I had wanted to relocate the batteries to the V berth to keep some of the weight out of the stern. I remember looking at some of Greg's pics (Aurelia) with the battery relocation mod. But now I'm thinking that seems like a bit more work then I really wanna delve into. Lol. I just had the idea of putting the 2 batteries in a double protective box and placing them on the floor in between the fuel tanks. It almost seems like the perfect place for the batteries. Plus isn't it better to keep the heavy weight low to the ground rather than high up in the gunnels? Also in doing that I will have freed up the 2 gunnel boxes for extra storage.....Thoughts? OR should I just leave them both in the boxes where they were designed to go? Haha
I didn't do a search for this question on the forum; I hope it hasn't been discussed ad nauseam. LOL!
My house battery is located between the fuel tanks an I like that location. I wish the other battery was located there instead of in the starboard gunnel hatch.
Dan
I have 2 group 31's between the fuel tanks, in battery boxes. Works well for me.
If you put both the batteries up forward, you are gong to have to run some very heavy cables to have the proper cranking voltage and amperage at the starting motor.
Also since this is in the cabin, you will need AGM batteries. Flooded lead acid batteries give off hydrogen gas, and thus are dangerous to place in a cabin.
Getting the weight out of the stern worked great for my 16 Cruiser. When moving the batteries more than a couple of feet, the new cables and fittings will seem ridiculously expensive. If you are moving them 10 feet, figure $5-6 per foot for your new cables and $25 worth of fittings. It's easy to get to over $100 in costs for "wire." It is possible to go cheaper (like I did), but making up battery cables to protect them from the marine environment becomes more complex.
On my boat, moving the weight around made a huge difference in the ride. The boat was so stern heavy that I would have needed trim tabs to get it to ride properly. The batteries are now at about the center of gravity and my gas tank is forward. Yesterday's sea trial was with 1/2 tank of gas and the fact that the tank is getting lighter doesn't seem to effect my ability to get the boat to ride correctly with just the motor trim. Getting the tank and batteries out of the stern was the major improvement.
Mark
Sounds like a decent plan to me. I have our starting battery in that location between the tanks to one side of the bilge and there is room for another on the other side where we currently have a tub for other items. It is more convenient to access the gunnel storage than the space between the tanks for most folks so it is a relatively poor location for batteries. I have noticed that many tank/bilge configurations on other C-dorys do not have the space for batteries like ours do so this is not an option for everyone.
http://www.c-brats.com/modules.php?full ... _photo.php
You could always consider putting just the house battery (AGM) up forward connecting into the existing panel behind the helm and avoiding the need for any long runs of heavy cable. That's what I did times 2. The factory wiring run along the stbd side can still be used to connect the front and rear batteries for combining, switching, or powering accessories in the stern using the house battery in the front. all you need are a couple of small buss bars or a small panel in the rear compartment for distributing the loads. I have a 12v socket back there connected to the house and choose to run the bilge pump from the start battery.
If you want to talk about the options or want greater detail of how ours are connected to the loads, just send a PM with your phone number and I would be happy to give you a call.
Greg
I too would love to move my batteries forward, and do not mind having sealed batteries .... I make my own battery cables... to reduce voltage loss.. I use arc welding cables with many more wires in them than regular battery cables and I solder on the terminal ends.... makes for very low resistance... so moving them would not be a problem...just finding a spot under the bunk to put them is a problem... would have to make my own battery box out of fiberglass...sure would be nice to move some of that weight out of the back of the boat....it sits a bit lopsided due to the weight of the batteries....I very rarely have enough water in the fresh water tank to offset the balance offset.
Joel
SEA3PO
If you can live without battery boxes, you can floor mount battery trays that help stabilize and add support needed.
http://www.jmsonline.net/battery-tray-2 ... oCv0jw_wcB
A battery box provides for venting control, spillage control, and physical damage or short circuit control.
Using a sealed, non-venting AGM in a contained, dry (under berth) environment with simple battery post covers is protection enough in my opinion. Controlling movement of the battery itself (strap it down) and protection from any cargo sharing the storage compartment (spare anchor) would be the key concerns.
Greg
Aurelia,
I'm in the noodling stages on a new house bank (two batteries), and thinking I'd like to put them where yours are (just forward of after bulkheads under V-berth). I'd be keeping the start battery in the starboard lazarette.
This conveniently puts the house bank close to the main house loads (helm area) and the (future) windlass, so that's tidy. And I'd have a "feed" running aft for a few things there (bilge pump, trim tab relay, etc.).
I figured I'd need large cables due to voltage drop if wanting to start the engine from the house bank, which I'd like as an option (I want to be able to combine for charging too; but the alternator is rather small so that's closer to 20 amps). Making the cables up is no problem, as I have the tools and "extra stock" of most larger cable sizes. What I'm not sure of is how much the main engine starter draws (Yamaha 80, but would also like to plan ahead for possible 115hp re-power). A wild guess is 40-60 amps, but I actually have no idea (4000 watt gasoline generator in RV draws 60 amps...). Knowing that figure would allow me to calculate.
How did you handle this, and do you know what the typical ~90hp outboard draws for starting?
Side note: I currently have a Blue Sea ACR and a Dual Circuit plus battery switch (along with house and start battery all in starboard lazarette). I might like to fit something a bit more "manual" for directing charging but not sure on that. The ACR is convenient, but what I have found in my RV is that with solar (which I'm going to add to the C-Dory as well) I prefer to only use engine alternator charging when necessary, which is not that often. Reason being that the solar charger is quite "smart" and good to the batteries, and the engine alternator is fairly dumb. So for the 95% of the time that solar keeps the house bank easily topped up, I figured why use the dumber alternator. Hence I just combine manually for the few times its necessary (two or three times in the past year). OTOH, I don't tend to RV in cloudy areas, but I do like to boat in them (PNW!), so would probably be combining more often. So maybe just keep the ACR, or have both options...
Anyway, I'm interested in how you've done it. I think I see in your album that you have a B2B type "smart" DC charger between the engine alternator and the house batteries? If so, how do you like it?
PS: I'm thinking either a pair Lifeline GPL-4CT (6 volt) for the house bank, or else a pair of their Group 31 or 27's. Any of these would be around 200 ah. Based on my RV usage, 200 amp hours should be about right. Reason I'm considering the 4CT (6 volt) is that I'd save one large jumper cable running under the V-berth footwell (since a 12 volt pair would need the power cables coming off opposite ends, either the positive or negative cable would have to go "out and back" so 33% more large jumper cable). With the 6 volts I'd just have a single loop. Various pros and cons, and either way will be similar in reality/usage (for example, no idea how often folks just have one of a pair of batteries up and die and thus are glad they have two 12 volt batteries). Just figured I'd mention the batteries on my possibility list. I have Group 31's in the RV (12 volt), but they are not separated by a footwell so the jumpers are short :D
How did you handle this, and do you know what the typical ~90hp outboard draws for starting?.......
Sunbeam, the manual for your vintage Yamaha 70 hp outboard calls for:
Minimum cold cranking amps (CCA/ SAE):
380.0 A
Minimum marine cranking amps (MCA/ ABYC):
502.0 A
A 4000 watt generator uses a 8 hp gas engine!
It is difficult to measure peak draw on an outboard starting circuit because it is of short duration. But not unusual to draw a 550 CCA battery down o 10.5 volts or lower transiently during start.
Welding cables are used at times in high draw (starting)situations, but boat starting cables should be tinned, especially if in a marine salt environment. I have seen welding cables become a mass of corrosion in some boats with salt water exposure--even salt air...
You would need at least 2/0 cables to go from under the bunk to the engine, if the battery were to be used to starting. West Marine price on this is $8 a foot, if you go to 3/0, then $12 a foot--x about 40 feet.
The other item which seems to be ignored in this discussion is fusing:
ABYC:
Overcurrent Protection Device Location - Ungrounded conductors other than cranking motor conductors shall be provided with overcurrent protection within a distance of 7" of the point at which the conductor is connected to the source of power measured along the conductor. (See Figure 11.)
EXCEPTIONS: 1.
2.
If the conductor is connected directly to the battery tenninal the 7 inch dis- tance may be increased up to 72 inches.
If the conductor is between the source ofpower, other than the battery ter- minal, and the required overcurrent protection device, and is contained throughout its entire distance in a sheath or enclosure such as a conduit, junction box, control box or enclosed panel, the 7 inch distance may be in- creased up to 40 inches.
So in this case, there needs to be a fuse within 7" of the battery, of the capacity to carry the max load. If you are gong to use this as a starting circuit--even occasionally and have the cable in place,--this means at least 550 amp fuse. A smaller fuse is needed separately within 7" of the battery for the "house" circuit.
In Greg's installation, he properly has terminal covers. This is essential--by all standards, One of the reasons I use a battery box, is that does give good terminal protection. (Having an anchor in the same compartment as a battery, with only terminal covers sounds a bit frightening to me. I don't know what the odds are of a fluke of a battery getting thrown around and cutting thru a rubber or plastic cover, and shorting the battery, but I would not take a chance.
Finally..one reason not to put batteries way up forward: That is that the battery is subject to a much harsher ride in the bow--if the boat pounds, this is hard on the battery plate separators. It may lead to premature shorts and failure.
I have put batteries up forward in large boats--where I had 24 volt battery requirements to run a thruster or a large windlass. But these were very heavy boats which went at displacement speeds.
380.0 A
502.0 A
ABYC:
EXCEPTIONS: 1.
2.
380.0 A
502.0 A
ABYC:
EXCEPTIONS: 1.
2.
Thanks for your thoughts. I was trying to be brief (for me, anyway), since it was not originally my thread, but I guess I should have added a bit more info.
380.0 A
502.0 A
I have an F80, but that sounds like about the same spec. What I didn't see was any data on what the starter draws in amps. Sorry to mention the Onan - obviously completely different (but I had a similar "hunt" to find what that starter drew when I was re-wiring it - turns out it is around 60 amps in case anyone wonders)
Too bad they don't publish the spec in an obvious place. Seems key for calculating cables and etc.
Good point. All my wire is Ancor, so it's stranded and tinned.
I have 4/0, 2/0, and 1/0 in stock, so was going to base the size on the starter draw vs. the length of the round-trip run. Top of my head thought is that it will probably be 2/0. I already have the wire, so no immediate cost to me for it.
Sorry about not mentioning fusing. I was trying to keep close to the OP's question (not that OCP is not important, but just realizing I was already piggy backing onto another persons's thread, and I am clear on the fusing but not clear on the starter draw of the outboard). I'll fuse for the wire (whatever that wire size ends up being), and it will be with a Blue Sea MRBF, so right on the positive terminal (another good reason for moving my bank, as I don't have the height for one where it is now). With only the two batteries, I'll still be under the 10,000 amp short circuit rating, so can use the MRBF (has an AIC rating of 10,000; in my RV I had to go to a class T, because I have three batteries and they call for an AIC rating of about 13,000 amps). Although ABYC gives an out (starting), I still prefer to fuse, so I'd rather use hefty wire that will allow a large enough fuse to not be an issue (just need to know what kind of amps I'm talking about).
I'm not sure if you are addressing me here, but I won't be putting my batteries in a compartment with anchor(s). They'll be just ahead of the bulkhead that divides the main cabin from the V-berth, so just a bit forward of amidships. Also, I'll have them secured and with terminal protection (as they are now in the laz also).
I hadn't thought about pounding. I wonder if it's a problem for AGM's? Reason I say that is that quite a few off-roaders (land vehicles) have switched to AGM starting batteries for that reason (shock loads apparently not being kind to flooded batteries). I don't have any idea of their credentials though. I'll look through my Lifeline manual again with that in mind, and if I don't see anything I will contact Lifeline and ask them. Would be interesting to know if they'd get more "action" just forward of amidships underway (where I'd like to put them - not way up in the bow in my case) or in the stern when towing (my trailer rides pretty well, but some roads....!!)
Very timely topic for me. Thanks to the OP for asking and for everyone's input.
I installed group 31 12v batteries but the others will fit a bit better. I found them to be pretty snug and when I have to replace them, I will use group 27 or even 24 instead depending on our power needs at that time.
The cable run from side to side actually goes under the space beneath the portapottie. I installed a small hatch rearward of there for tool storage and used that access to easily pass the cables from one side to the other using short lengths.
A quick amp draw search came up with this general range... A 90hp motor will draw about 90amps to start in ideal conditions. It can also draw as much as 300amps in challenging conditions.
I use a 100amp Yandina combiner with the features below. This is the smallest model and there are units large enough to use differently. I never planned to start the motor through the combiner but instead carry a set of compact jumpers I made to jump from bank to bank or buss bar to buss bar in the rear lazarette. The latter option would use the factory stbd wiring and while I might do that for "charging" a dead start battery, I would disconnect them during the actual starting process due to the light wiring and distance. Most likely I would go straight from the terminals on one of the house batteries to the terminals of the start battery and start it up directly. Only a real battery failure would require this move but I am ready for it. I am pretty sure I still have the bilge connected to the start battery so that is the only possible draw, but I may have moved those wires over to the house last summer. Not remembering for sure right now. Our living room of a cockpit means the space is very dry so the bilge hardware is largely cosmetic in our case.
Features:- I indented some that relate to this discussion
---◦75 amps continuous rating, 400 amps closing current (2 seconds), 100 amps for 5 minutes
---◦Suitable for alternators up to 100 amps, up to 18 volts. Larger charging sources should use the Combiner 160.
◦Waterproof - Ideal for exposed mounting in open boats
◦No voltage drop so batteries reach full charge
◦Electronic thermal monitoring with shutdown and automatic restart.
◦Minimal wasted power, no heat sink or cooling required
◦Can be used on alternators with internal or external regulators
◦Alternators with external voltage sense require no special wiring
◦Simple basic installation, two battery wires and ground
◦Complete with all cables and terminals for basic hookup
◦Green LED indicates when combined
◦Red LED indicates temporary thermal overload shutdown
----◦Draws no current when batteries are not being charged
◦Draws less than 150 milliamps when charging is in progress
◦----Optional external remote control for off, automatic, on
----◦Remote "ON" can be used for assisted engine starting
----◦Remote "OFF" can be used to disable the combiner.
◦Withstands ambient temperature to over 175 F for exposed or engine compartment mounting
◦No diodes to burn out if accidentally shorted
◦Compact - only 2.5" wide including tabs by 1 5/16" thick by 1.5 high (plus cables)
Bob, the Anchor stored with a battery was about the worst case example I could think of for shorting or damage potential. I actually do keep both of my small (less than 3lb) anchors in bags in one of the compartments with a battery but the way I have them contained, they can't gain any momentum or get through the bags and pfd the separate them from the battery.
Also, AGM batteries are perfect for application where vibration or shock loading occurs. The design is made to perform in vehicles and applications where these actions are expected. Here is a general idea of the build difference. "In AGM batteries (also called starved electrolyte), there is a thin ultra-fine fiberglass mat sandwiched between the plates that are saturated with battery acid to about 95% of what they can hold. This mat is then packed in between the plates and slightly compressed, then welded/soldered in place. Because the plates and mats are packed fairly tight, they are almost immune to vibration."
Greg
Thanks for the additional info, Aurelia. Very good to have the ballpark figure of 90 amps. Even better, you have caused me to re-think my strategy perhaps. Always fun to consider alternatives in the planning stages. When I upgraded a similar system in my RV (switched cable from start battery to house bank for primarily charging but possibly starting), it was not really any "extra" to set it up for starting, because to get a reasonable voltage drop for the alternator current going back to the house bank, I could also properly fuse for the starting current that might run from the house bank to the start bank. So it was kind of a no-brainer (even though I have never had to use it yet, and I also carry jumper cables and an anti-gravity start pack).
On the other hand, maybe it's not such a no-brainer on the boat. After all, the alternator puts out less than 20 amps (maybe up to 35 if I re-power, but realistically probably closer to 25), so the wire size capable of carrying that (with low voltage drop) might not be also capable of the starting currents (now that I have the 90 amp figure, I'll run some calcs). On the other hand, I have lots of large wire on hand. BUT, I'd still prefer to avoid the weight of huge/long cables. (OTOH, jumper cables would be similar perhaps...) But now I have something to use in my figuring, so thanks!
Okay, ran some calcs. Used 40' round trip (rough guess on jumpers plus feed from helm area busses to lazarette starting batt busses). Maybe I won't need 2/0. Using 90 amps (starter) and 2/0 I get 2.9% voltage drop; at 30 amps (theoretical future better alternator) it's 1%. With 1/0 those figures go to 3.7% and 1.2% respectively. However if I were not starting on that line, and only charging, then 2 AWG and 30 amps is still only 1.9% voltage drop (90 amps is 5.8% - not acceptable for my comfort). On the other hand, I was already figuring on using 2/0. Looks like I could use that or even 1/0 and still not have to carry the jumper cables. Any of those wires could easily be fused to well over 90 amps. Hmmm. I'll have to let this percolate and see if there is anything else I want to think of. Oh right, the cables that already come off the engine. Those must be no larger than 4 AWG and are probably three feet long (not that I've measured yet). Well this is why I noodle and sketch for awhile before proceeding (and hear what others have to say).
It will be interesting to see how often I want to combine for charging as compared to the RV where I almost never do (solar power keeps my batteries happy and has a smart charging curve). But then I don't tend to RV in the PNW, so my guess is I WILL want to use the engine's alternator for bulk charging at times. I don't want to cut that option out.
I'll have to go back and read more carefully on the Yandina, as that is something I had not previously considered, but just was aware of its existence.
BTW, everything in my boat runs off the house bank except for the engine starting and the engine tilt/trim. Of course things can always be re-wired if desired. Both the bilge pumps ('midships and transom) run off the house bank.
I had also thought about just running one bank (essentially a house bank) and starting from that, but ultimately I think that sounds a bit too "wild" for me, so I want to start from a dedicated start battery. It's bad enough not to have sails as backup :mrgreen: (I considered it briefly due to the number of folks who run with one bank (house bank which is also used as start bank), and then just use the start battery as a "reserve" for emergencies - apparently with larger house banks instrument drop-out etc, may not be a problem when starting from house bank. But anyway, at least this go-round, I'm going to stick with a larger house bank (around 200 ah) and the smaller dedicated starting battery.
Thanks for the confirmation on vibration not being a problem for AGM's.
I was just on my boat yesterday and thought (from poking around in the space) that I could run the battery jumpers under that "sole" molding aft of the Porta Potti well. Good to know you found it workable in real life. I found a nice pocket right aft just before the step into the main cabin. If I run a pair of 6 volt batteries, then it will just be one jumper "out" and one "back."
Sorry for the multiple posts--checking back to the site showed that none had gone thru.
Only part of the thread was addressed specifically to Sunbeam.
Sunbeam I would fuse for 500 amps as an inrush current for the starter. You might get away with less, if you have immediate start. However, having carburetors, you probably have a longer start time on an average, than an injected engine. (broad statement--depending on may factors)
There is an excellent article on fuse size for staters (but these are small sailboat diesels--about 30 HP)
http://forums.sailboatowners.com/index. ... ow.130775/
The AIC (Average Inrush current() is difficult to measure unless you have a sophisticated instrument. In the above link the writer has a Fluke 376 meter, about $300. There are multiple variables which determine the AIC.
Generally boaters don't worry about AIC. Builders should, but often they don't either....
You fuse for the current, not the wire size. .Fusing has two functions--primarly to prevent overheating in the wire and cause a fire in the boat (or vehicle). Secondly some electronics call for a smaller fuse, because they have internal components which need protection.
The alternator charging wiring, has no relation to the size of the starter wiring.
You say you have 4.8% drop in voltage when starting off an aux battery--measuring both voltage and inrush current is very difficult, unless you have a very sensitive datalogger, the peak current, and low voltage are difficult to read because of the time in microseconds. ABYC calls for no more drop than a voltage to 1.2 per cell, or for a 12 volt battery of 7.2 volts in the battery. Also when using a "booster" which most RV's do--you are using a solenoid which allows the house and start battery to work in parallel. (not sure if you wired your RV differently than what is the convention.)
AGM are more rugged, than a Flooded wet cell--but even more rugged is the gel cell. Gel cell has other issues, which make it less than ideal for outboards. There are those who say that the serial wound are more rugged. I have not used the spiral wound, for some personal prejudices..
The least motion is further aft in a boat. There will be more pounding, but perhaps slightly less vibration forward. The pounding is what is more likely to damage the battery. (The C Dory 25 purchased had been pounded to the point that there was some delimitation of the tabbing of the V berth platform. Also a little at the forward bulkhead.
For the most part outboards are within the factory supplied cable length for the starting motor to the battery. The cable is undersized for extended runs. If you are going to mount the starting battery 15 feet (wire distance--not round trip, which is used to measure the wire size), you should terminate the factory cable as near to the motor as possible (and keep the terminal in a dry and protected location). The air then should be the size determined by the amount of current--and I would doubt that the smallest main motor (40 hp) would use less than 200 amps.
I've had that happen before - then you see you posted three times, ergh. I wasn't sure which parts were to me or others.
Hmm, okay. Well I had to research this for fusing on my RV (as built, the 4AWG line from start battery to house bank was unfused, although it was set up for both charging and self-jump-starting). So I looked around to find the starter draw (in my case on the RV, about 150 amps). Then I wondered if I had to account for inrush current. I found an article by Maine Sail, and he said that no, that's too "quick" to fuse for, and that essentially one just fuses for the starter draw. I went with that (used 1/0 Ancor cable, fused at 200 amps; 242 is allowed in an engine space for that size wire, unbundled). Now, I have not had occasion to test that, but a friend with the same RV/engine (gas)/cable run (but only 2 AWG wire, he likes to cut it a bit closer) had a period of time where he was chasing a parasitic load, and did have to "self jump start" a number of times. He was fused at 175 and did blow the fuse once, so that seems to say it was "close" on fusing at that level. He chose to up the fuse to 200 amps and has not blown it since (still an improvement over his original setup, which was a 6 AWG wire that was unfused). Since the starter draws ~150 amps, this seems to say that the inrush current is not affecting the fuse (The spec I found said "typical starter load 130-220 amps; maximum load, 800 amps," which I think is the inrush current. Let me see if I can link to the article. Anyway, that's what gave me the idea that inrush current did not need to be "fused for." Would it be different on an outboard?
Here is the article:
http://www.pbase.com/mainecruising/battery_fusing
The part I'm thinking of is where he says (in reference to fusing starting banks, which he is a proponent of):
Question: "Won't the starters inrush current blow my fuse?"
First, what exactly is "inrush current"? Inrush current is the very brief spike in current that the starter undergoes to get the motor to begin turning over from a stopped state. The inrush duration is usually about 200ms to 250ms long, and not long enough to blow a properly sized fuse. ANL, MRBF or Class T fuses are not sized for the inrush, they are sized to the wire they are protecting.
This video below shows the absolute peak inrush as captured by a Fluke 376 meter. The engine is an older 2QM20 Yanmar. The absolute peak current draw, perhaps 2/10th of a second, is 316 amps yet this motor is protected by a fuse rated well below the inrush. It has never blown nor will it at this inrush capacity. The average starter load during the duration is closer to 150A.
BTW, my Yamaha generally starts right up with no extended cranking. Maybe it's because I don't tend to be trying to start it below around 40ºF, or maybe just lucky. I did have all four carbs rebuilt when I got the boat (it had been sitting) and I drain them all between trips.
Okay, I think we "crossed acronyms" perhaps. I was meaning "Ampere Interrupt Capacity" for the fusing. i.e. not the size of the fuse, but the "toughness level" of the fuse holder or body itself. The Lifeline Group 31 (27 and GC-4 are similar) have a short circuit rating of 3,564 amps. So with two I'd need an fuse/holder AIC of at least 7,128 amps. That's fine for the MRBF which is rated at 10,000 AIC. (On the RV I have three Group 31 XT, so that requires an AIC of 12,771 amps, therefore I used a Class T main fuse (AIC 20,000 amps).
Okay, well maybe I've been going at it a little backwards, but the way I've been doing it is I see what size wire I need (usually voltage drop being the deciding factor for the kinds of things I do), and then I see if it has enough/plenty of ampacity (i.e. can I fuse it high enough). If not, I go to a larger wire size, but I still fuse for the wire (and choose the wire based on the load). Whenever the wire size goes down (say at a fuse block or buss bar), I re-fuse if the smaller wire doesn't have enough ampacity to be covered by the fuse on the previous (larger) wire. I have at times just upped a wire size because that was more convenient than re-fusing (space, say at a bus bar). Maybe just another way of saying the same thing (?). If I have something on the end of the wire that needs a special (smaller) fuse, then I'll just use that smaller fuse at the fuse block if the wire is only feeding that item. After all, in that case there is no reason not to fuse smaller and avoid a bunch of fuses or (shudder) inline fuses all over the place.
Okay, maybe I'm out of the loop here. I was thinking of the cable that would be running from the start battery's bus bars (which is where the outboard connects, and there is no separate wire from the outboard for the alternator) to the house bank's bus bars (if the house bank is moved). In my mind this will be carrying the alternator output to the house bank, and possibly also the starter draw if I combine (or just simply start off the house bank). Is this not correct? This is how it works on the RV. I don't see any cables that would separate the outboard's alternator output from the starter draw in terms of the cables that carry it from my batteries? What am I missing?
You've kind of lost me in the first part, but for the latter part, no I don't use a solenoid on the RV. It originally had a Surepower 1315, but I eliminated it for a few reasons. One is that it was recalled (slight matter of them catching on fire). Two is that it was of the old-fashioned type that causes its own voltage drop. Three is that it was bi-directional and I only wanted it to go "aftward." I considered a Blue Sea 7622, but instead went with a Blue Sea On/Off battery switch. I also have a pair of LED lights wired to the switch. When the batteries are combined there is a solid green light on the dashboard, and a flashing red light in the coach. This is so I don't forget and leave them combined. I can reach the switch from the driver's seat or the rear of the coach. As it turns out, I rarely combine any more because with just the solar I only get below 85% charge on rare occasions. The start battery doesn't have any parasitic loads (or at least not any that show up in a period of a few months), so I don't charge that between drives. I've combined the batteries twice in the past 9 months, for about 6 hours each time, so having a manual switch has been perfect for me. If I did it more often I'd likely go with the 7622. I do have a Blue Sea ACR on the boat (but then so far I have not had a robust/separate house charging system on the boat, which I do have on the RV -- so I have relied more on alternator charging, and therefore pretty much always want to combine when underway. That may change when I get my alternate charging methods set up).
Although for the most part folks ignore the difference, there are two stages of starting. The first, or inrush current is power to start turning the outboard motor. This is high, and can be up to 1500 amps. It is of short duration, and most meters (including the ones I use) cannot measure this short duration.
This is from the Blue Seas web site on battery switches. Note the initial spike of over 1000 amps--but a brief duration, then the longer curve as the engine is rotating before it fires.
When folks give the "amp draw" it is that part of the flat curve, or average, not the higher inrush current. or in some ways the more important part getting the motor turning. The issue with inrush current is more with circuit breakers, where the contacts may be fused if the current is too high. Also it can be with fuses where the fuse arcs during blowing. These both are fire hazards.
Just wanted to mention that -- I guess because I was trying to keep too many posts in mind as I replied -- I was thinking you were talking about the B2B charger. Reading more, I think I see now that you are talking about an ACR type device. (I have a Blue Sea ACR on the boat now.)
One other thing: I was thinking "Well gee, if he's going to carry jumper cables, why not just wire with heavier cable and "carry it" that way? And not have to stow cables? But I think the penny just dropped. The reason this may be a good alternative is (I'm guessing) because you don't have to fuse the jumper cables (they are not built in and you are only using them while present and watching them in rare situations). Thus your feed wire from stern to house batts amidships need only be sized and fused for the current and desired voltage drop of the alternator. Am I on track with your reasoning here? Interesting alternative. Since I already have lots of large cable, I may still choose to "hard wire" (with appropriate OCP), but I like options to think about, so cool!
Good point. There's no particular reason for me to keep the long and relatively thin (and not all that nicely terminated) stock outboard positive and negative cable. I think I'll cut them off in the starboard lazarette (where I have a number of other wiring things) and transition to larger cable. It may be convenient to do this at the battery switch and negative bus, or perhaps I'll use a Blue Sea 2016 -17 or -18, depending on how it works out.
(No, I don't have stock in Blue Sea - but I probably should! :mrgreen: :mrgreen: )
Sunbeam, you are very much on track. I did use a B2B charger in another boat and was happy with that unit for the charging I needed and that battery combo.
I went with the Yandina combiner this time to stay more compact and do the power sharing, switching, and isolating we needed to run a cruising boat. It also eliminated the need for any physical parallel switches. The yandina is the only connection between our house and start batteries. I considered "wiring in" a set of heavy built in jumpers but after going through our needs and my final setup, I decided I would not likely need to jump our own boat so a portable set would be much more useful for the other boats I would be more likely use them on (one so far). The distance from the house battery to the start battery is 11ft so I made a light set 12ft long. They fit coiled up in a large peanut butter jar and are always on board. They also provide me 24ft of spare marine wire should I need it for something.
That type of power post pictured in your last post works very well for connecting outboard cables to start battery lines. I used one in the stbd lazarette for that purpose.
Greg
