416rigby
- Joined
- Mar 31, 2004
- Messages
- 1,208
- Reaction score
- 0
- C Dory Year
- 2001
- C Dory Model
- 22 Cruiser
- Hull Identification Number
- 3605656779
- Vessel Name
- Foggy Dew
I found this quite interesting. A quote from the C-Dory factory website in the "construction" pages.
Pretty straight forward...seems like an excellent construction method. Sure seems to produce one tough boat.
On another thread, I read this:
Hmmm...if true, any thoughts? Could this be the end of yet another era?
Rick
The hull and it's cabin and deck components are laid up separately and then their molds are assembled together. The parts are then fiberglassed together while still in the molds to insure perfect alignment and to eliminate any possibility of twist. This process is time consuming, but yields a far superior hull to deck joint than any mechanical system.
Also mentioned by Tom was the development of a 'shoe-box' deck seam for the 22. The deck will be dropped over the hull and epoxy glued and bolted together under the rub rail. The deck won't be bonded to the hull while the parts are in their respective molds anymore. This will speed up the boatbuilding process.
The above information is as I remembered it from what Tom Latham said at the factory party. I could be wrong about some of this, it was a party after all!!
I hope the factory guys will comment on this after the boat show ends. We should get the strait story directly from the factory.
Rick
