C-Wolfe
Active member
- Joined
- Sep 16, 2020
- Messages
- 408
- Reaction score
- 29
- Location
- Anchorage
- C Dory Year
- 2008
- C Dory Model
- 255 Tomcat
- Vessel Name
- Callisto
I am considering replacing my fuel line because, one,I believe they are original from 2006 and its probably due and 2nd my primer bulb don't work so good anymore.
1st, other than the hoses anything else I should replace? I have 2 Racor fuel filter/water separator that have the supplied plug (metal) install in the unused port that is now all rusted. Should the filter head be replace periodically? I'm guessing I will anyway but I'm wondering if this is something that should be replace more frequently then every 15 years.
2nd I'm thinking of installing a quick disconnect at the filters spare inlet so I can use a portable fuel tank and have it go thru the filter and another one at the 2nd outlet for the kicker. anybody see any issue with this setup? I do like the honda round quick disconnect , they should be easier to keep fully cover when not in use and they have been the cleanest that I have used. I do have a 3 way selector valve that probably should be in the off position while using the portable fuel tank.
