- Joined
- Sep 30, 2006
- Messages
- 4,673
- Reaction score
- 1
- C Dory Year
- 2007
- C Dory Model
- 25 Cruiser
- Vessel Name
- 'Au Kai (Ocean Traveler)
...and it's possible complication.
We just spent a couple of nights at Friday Harbor. They have done some upgrades to H dock (and others) including new 30 amp shore power pedestals. We tried to hook 'Au Kai up, but the breaker would instantly trip at the pedestal. I tried a neighboring pedestal. Same thing. I called up to the Harbormaster office and a maintenance worker came down. We went thru my steps on how I connect it. Correct. (We have a dedicated 30 amp at home and the boat was hooked up all winter, so this confused me) That's when he told me the "issue" lay with how the boat is wired. The new pedestals now have GFCI breakers installed. He said the marina was mandated by up-dated code to install them. Since then, they are seeing quite a few boats with the same type of issues. Since the season and pedestals are all brand new...the issue has suddenly arisen. I'm sure I'm not alone.
So I did some research. There is a new NEC code standard (Article 555.3 issued in 2011) that came into effect in in 2014 that requires the use of GFCI breakers at all marinas. Basically, the electricity is disconnected with 30 milliamps of ground fault leakage. This is the new standard. If a marina updated or rebuilt for whatever reason, they are now mandated to comply.
This article explains it in detail: https://www.powerandmotoryacht.com/maintenance/why-some-boaters-suddenly-cant-connect-to-shore-power
Our boat's issue lies with the transfer switch (the main breaker) because the symptom is this:
So I may need an AYBC certified electrician to diagnose and solve this. Or maybe I need one of these installed: https://www.boatus.com/seaworthy/magazine/2015/july/isolation-transformers.asp The article noted that this may solve the issue and provide other benefits. Since I'm dealing with electricity on a boat, I may just hire a professional and have him solve it the correct way.
Exactly our experience.First, turn off the primary breaker in the shore power connection. Then, turn off all branch circuit breakers within the boat. Once the shore power cord is connected and locked into place, turn on the shore power connection at the dock pedestal, with the boat’s main AC breaker still off. ...turn on the boat’s main AC breaker with all of the branch circuits still off. If the shore power pedestal breaker trips, the problem is likely an improperly wired transfer switch or inverter.
