Well-known member
- Joined
- Nov 2, 2003
- Messages
- 21,897
- Reaction score
- 239
- C Dory Year
- 2007
- C Dory Model
- 25 Cruiser
- Hull Identification Number
- DOR25652A707
- Vessel Name
- thataway
The anti-siphon valves are more important in tanks which are inside an enclosed space, where fuel might siphon out of the tank if the line is disrupted.
In the Tom Cat, I had a bad anti siphon valve from the get go...So they can be bad at time of manufacture...
There are also check valves in both ends of the squeeze valve.
The reality is that we don't need them in most of the C Dorys. but Federal Law requires them. In a pinch I have replaced an anti siphon valve with a straight hose barb fitting. (I always carry a couple of hose barbs fitting sized for the boat's fuel ports, including the Racor Filter. Just in case.
I also had one case where I had used teflon tape on a fuel connector and a small tab of the tape got into the fuel flow area--was causing an intermittent obstruction to fuel flow. There can be cracks in the pickup tube which cause obstruction. Also there is a filter on the bottom of the pickup tube which can be fouled with debris.
FEDERAL LAW
183.568 - Anti-siphon protection
Each fuel line from the fuel tank to the fuel inlet connection on the carburetor must:
(a) Be above the level of the tank top; or
(b) Have an anti-siphon device or an electrically operated fuel stop valve:
(1) At the tank withdrawal fitting; or
(2) Installed so the line from the fuel tank is above the top of the tank; or
(c) Provided that the fuel tank top is below the level of the carburetor inlet, be metallic fuel lines meeting the construction requirements of Sec. 183.538 or “USCG Type A1” hose, with one or two manual shutoff valves installed as follows:
(1) Directly at the fuel tank connection arranged to be readily accessible for operation from outside the compartment, and
(2) If the length of fuel line from the tank outlet to the engine inlet is greater than 12 feet, a manual shutoff valve shall be installed at the fuel inlet connection to the engine.
