Wood Zeppelin
- Joined
- Feb 9, 2016
- Messages
- 364
- Reaction score
- 0
- C Dory Year
- 1997
- C Dory Model
- 22 Angler
- Vessel Name
- C-Creature
I was able to find a used version of the upgraded lower unit design for my 1998 Honda BF40. I got it all put together and went for a test drive today. There is a noise I never heard before, kind of a "whirring/ringing" sound that occurs between about 2000-2700 RPM.
With the motor in neutral, I can manually spin the prop just fine, no noise or anything. Here are the things that have changed since before the noise:
New (used 2007) lower unit.
New impeller
New gear case oil
New prop (different pitch as I've gone from sea level to 3000' elevation)
Elevation change: using the 3000' prop, but I'm now running at 6000' elev.
h
My fear is that after dropping $1000 on a *used* lower unit, there's something wrong with it?
Or could it be something else?
Should I even worry since it sounds just fine above and below that RPM range?
New impeller
New gear case oil
h
