ATPNW,
It would be great if you would say what your name is... Otherwise, I feel like I am only talking to a machine.
As to your oil leak:
1. Take a sample of oil from your dipstick and a sample of oil from the stuff dripping out of the lower unit. Touch it and smell it to ensure that it is the same oil. Lower unit 90W gear oil has a completely different odor and color.
2. When I replace crankcase seals, I disassemble the entire engine (powerhead). Each part is cleaned, inspected and measured to ensure that it still meets manufacturers specifications. If a part can't meet spec, then it is replaced.
3. Assembly includes replacing of all parts not within spec, parts that show excessive corrosion, all new seals, gaskets, filters, oil, lubricant. The repairs also include the same inspection and service to the mid section and the lower unit.
So, a quick repair can't be anticipated and the expense will certainly be in the hundred of dollars (for all parts not including labor). This is the way that I do it and i'm careful to ensure that the outboard will perform as new, to ensure reliability as well as confidence.
Best regards,
Steve Baum
