Active member
- Joined
- Feb 23, 2012
- Messages
- 3,990
- Reaction score
- 16
- C Dory Year
- 2002
- C Dory Model
- 22 Cruiser
thataway":2huiwobl said:Then I would suspect that there is an issue with the way the motor is mounted. ... If your Permatrim is not running on the surface (which I believe you said it was not), then the motor is lower than ideal.
That is the case, and I suspect the same as what you say (I think it may have been your link that had the photos of the correct height).
Interestingly, I have been looking at where the four transom holes are on a number of 22 Cruisers. They all seem to be in close to the same location - so perhaps there is some "usual" guideline for where to put them. However, the "hole heights" used on the engines vary. For example, mine is set in the second hole down from the top and there are four adjustment holes. So I could raise my engine two holes (and probably will).
Theoretically the holes in the transom could be slightly higher, but not very much because the washers/backing plate on the inside of the transom would come up over the top edge.
