Well here is the final report on my possibly incorrect winter lay up. We have a Honda 90 2005
We had a carb problem the end of last season. Turned out dirt-aluminum chips in the carbs. Must have been from new but took a long time to cause a problem. When it happened last fall I thought it was due to E-Gas. Changed all filters ect, found no water or problems so it went to the dealer and they found the chips.
At this point the tanks were about 1/4 full. I have been useing Starthon every time we fuel. I read an article about storage that said not to fill up, because the fuel will go bad any way. I added a little more Starthon and ran it thru with the ear muffs and did not run the carbs empty.
After a long winter storage I ran the boat about one hour and all seemed OK. Today I added about 15 gals split between the tanks and went out for a navigation contest. After about 3 hours of rocking and rolling at six knots it ran up to 5800 with 4 people on board and never missed a beat.
I don't know if I got lucky or that Starthon really works. I will keep useing it that is for sure.
Fred, Pat and Mr. Grey(the cat)
