ActiveCaptain
I traveled to see a C-Ranger 25 tug for the first time (along with a CD-25 and a TC-255). I really liked the tug. It was hull #1 and I wonder how much has changed. The salesperson wasn't sure about a couple of things and I'm wondering if anyone can answer a couple of things:
1. Does it come with the thrusters running off the normal house bank? With this setup, the Raymarine electronics failed when the high load of the thrusters was drawn.
2. The upper half/topsides seems to be covered in gelcoat. The salesperson said that the rest of the hull (the blue part) was painted. Is this true? What type of paint is used?
3. The engine on the boat was the Yanmar 125. I know that this is no longer available. I thought that there was a problem with getting to one of the injectors (the one under the door). The rest of the engine seemed pretty good to work with. Has anyone removed this third injector without removing the engine?
4. The sound level was pretty good until we reached above 2,500 RPM's or so. I thought it was pretty loud after that (the cruising range). I also thought that there could be more sound insulation on the engine access inside the cabin. The noise level was high enough to make hearing the VHF difficult. Was this just me, this boat, or is there an issue with this?
5. The engine mounts were pretty small. I'd think that beefier mounts could help engine noise too. Were these changed in later models?
6. The salesperson said that all gray water goes into the holding tank. We didn't test it but that doesn't really make sense. It would be really nice if there was a Y-valve but we didn't poke around enough to think about looking for it while we were on the boat. What happens to gray water on this boat?
All in all we were left with a great impression of this boat. It has a nice fit with the type of cruising we'd like to do next (we're coming from a much larger trawler). The boat handles very well and has enough space to get by. Whoever designed this is very creative. The largest change that we'd need to make is turning that port side, inside "cave" into a storage system.
